Home > Td5 > Intercooler refit - correct installation question
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
.......Or where have I messed up..?
Finally refitting intercooler last night after flushing/cleaning a week ago..
However, I’m suffering memory failure, and am struggling with the exact location of the diagonal support struts which I took out and repainted. I’m sure they fit from bottom bracket to by the bonnet latch? But are right up against and touching the intercooler top housing when I place them.
Thanks for any pointers- need to get it all back together today, though shouldn’t take more than 10 minutes....
Robin
Post #704757 2nd May 2018 11:57am
jst
they do go there, is it std width intercooler?
not sure if they go inside or outside from memory. you may find if you have the top slam panel out or loose it will come in together when that goes back on without touching.
i have had to space out some brackets at the bottom to miss 'extra' thick intercoolers before. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #704760 2nd May 2018 12:18pm
DC101
Thanks JST,
I’ll try a loose fit assembly, as you suggest. Hopefully will become clear.l....
Post #704785 2nd May 2018 3:08pm
roel
On the outside:
 Roel
2003 90 Td5 (2009-now)
Post #705051 3rd May 2018 5:58pm
