Home > Puma (Tdci) > ABS , TC, Brake light |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
sounds like either an abs sensor or the main relay.
10th May 2011 11:08pm |
I had same problems....
http://www.defender2.net/forum/topic2394.html?highlight=abs If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th May 2011 9:46am |
