![]() | Home > Puma (Tdci) > ABS , TC, Brake light |
sounds like either an abs sensor or the main relay.
I had same problems....
http://www.defender2.net/forum/topic2394.html?highlight=abs If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
