Home > In Car Electronics > Another washer jet query
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I want to do the mod using the left hand drive wiper holes and install 2 separate jets using front and rear pumps for the windscreen, is it possible just to solder the wires together from both pumps so that both motors work from the wiper push button stalk or will this overload the wiring to the stalk. Whistle Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #703993 29th Apr 2018 3:47pm
mk1collector
Why would you want to? If all the kinks are taken out of the water pipe and the none return valve is ok then the pump for the front gives plenty of pressure for two front jets. Ray
My build thread
Post #704000 29th Apr 2018 4:10pm
If you did set it up as you describe, you'd have to be careful which way around it's plumbed in. The rear screen pump is higher than the front so that you can't leave yourself without water for the front screen.
As mk1collector says though, the front pump is perfectly adequate. This is the second vehicle I've made the mod to:
 Darren
Post #704021 29th Apr 2018 6:02pm
JR
Scotland 1984 Defender 90 200 Tdi SW Coniston Green
Re: Another washer jet query
I concur!
My 1984 90SW has had this since before I bought it in 12/1999 and has worked flawlessly and my vehicle was both a training vehicle, an off road trials motor and lives on mucky 'C-class' roads through farms. The only thing I had to do when I got it was swap the pipes round on the T-pipe to stop the water priority being on the passenger's side!
Post #704090 29th Apr 2018 11:48pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
I've binned the standard centre washer and moved to jets mounted on the wipers themselves. Locating the jets onto the wipers makes a massive difference - look into the VW type 99 wiper relay too Thumbs Up
As for using two pumps - no reason why not if you want a bit more oomf out of them. My mate runs his this way and I'm about to do the same as I've removed my rear wiper totally now.
There are a couple of conversion kits out there for a bigger washer jet pump, but might as well piggy back two if you have them for free.
Post #704093 30th Apr 2018 1:38am
jeffersj
Thanks All! Ross It was the wiring I was concerned about, what would happen if the 2 motor connectors were wired together? Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #704112 30th Apr 2018 8:15am
red zepplin
1998 Defender 90 300 Tdi HT Rioja Red
Hi got this mod on the zepplin plenty of pressure using 1 pump and a t piece just make sure the aim is spot on :thumbsup: but it makes such a difference and is so ceap and easy to do every in should do it even put the on the head lamps these are fed from the rear washer
[img]https://www.defender2.net/gallery/albums/userpics/18141/normal_20180430_104557.jpg[/img] WHAT COULD POSSIBLY GO WRONG
My sky lantern petition
http://chng.it/HJXmZC47
Post #704126 30th Apr 2018 9:44am
Maxxed_Ross
It'll increase the load on the wiring, so may be worth looking into a relay if you plan on using them for extended periods
My mate who has run this set up for around 5 years hasn't bothered and I'm not going to either
Post #704251 30th Apr 2018 6:51pm
VeeTee
Netherlands
I reckon this is a dash out job? Confused Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #704257 30th Apr 2018 7:02pm
Maxxed_Ross
Post #704439 30th Apr 2018 9:52pm
