Home > Puma (Tdci) > CLUTCH STUCK
Page 2 of 2 <12
scottchad01
Wales 2008 Defender 90 Puma 2.4 SW Stornoway Grey
That’s for the help guys, will Definitely look into aeverything you have mentioned!
And I’ve been having the same sort of issues fbaird03, and I’m also new to the defender scene, hopefully this will be it for a while
Post #699011 6th Apr 2018 5:25pm
agentmulder
Kuwait
It is a biggy, but once it's done you can drive no worries for a looong time.
Everything else puma or typical defender related is much easier to deal with, lots if info in the forums here to help you along if you need it. Solved the bowel problem, working on the consonants...
Post #699074 6th Apr 2018 8:24pm
biffabacon67
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
66000 on mine at the time and had the same clutch problem. Slave cylinder inside the bell housing.
Replaced the clutch plate etc. whilst in there, old one rattled like a tamborine with most of the springs utterly shagged.
Makes such a difference once you change it.
Post #703353 26th Apr 2018 5:34pm
scottchad01
ahh good to hear! i had to go back to university so left it in the garage, the work has been completed but too busy to get back and try it! not had a bill either, did you do it yourself or get someone else, if so how much was it roughly? Rolling Eyes
Post #703430 26th Apr 2018 9:07pm
biffabacon67
It was roughly about £700, i think. Just had the turbo replaced £912 with a lifetime warranty Shocked
Post #703717 28th Apr 2018 7:33am
Page 2 of 2 <12
