Page 1093 of 1378 <123 ... 109210931094 ... 137613771378>
Grenadier
What's the sticker surrounding the hinge on the right hand side of the picture Eric? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #702874 24th Apr 2018 4:02pm
ericvv
Post #702883 24th Apr 2018 4:15pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Having spent rather more than SWMBO thinks on a new engine and associated "necessary" bits (BAS intercooler new turbo, VCV, Nakawotsit wing to airbox pipe ++) and treated the Defender to new BFG's a couple of weeks ago I've now had the A/C condenser replaced prior to a trip to Italy next week. It may be a bit warmer there!
I never name my vehicles but I recon this one is female, she can never have too much attention Whistle
Post #702901 24th Apr 2018 5:47pm
Zed
ericvv wrote:
It is part of the matt black SVX stickering...
Eric
Extra 20 bhp right there.
Post #702902 24th Apr 2018 5:49pm
Grenadier
Eric
Ta. Thought it might be some form of protection. Thumbs Up Monsieur Le Grenadier
Post #703048 25th Apr 2018 11:09am
Grenadier
Any thoughts on that? Worthwhile upgrade? Not just the Naka inlet and pipe, but just generally having the extra mm in the air pipe, even if DIY ? Monsieur Le Grenadier
Post #703050 25th Apr 2018 11:12am
shropshiredefender
When I met Pete Bell (BAS) he looked at my OEM RAI and said that it restricted/ reduced airflow, so after further research it seemed to me that replacing the restrictive standard pipework with the larger bore Nakathingy would return airflow to standard or better, and keep a properly sealed RAI.
Given all the other stuff that happened at the same time as fitting it it's difficult to know if it, by itself, made a difference.
But, getting back to the principles of pre-ECU tuning, smoothing and increasing airflow always seemed to help.
Post #703074 25th Apr 2018 1:34pm
On my 2.4 I replaced my Mantec RAI and standard underwing pipework for the Nakatanega RAI, the one that exits through the top of the wing, not the side) and there was a very noticeable improvement in performance. The engine revs more freely and feels a lot less "strangled" at higher revs.
Post #703087 25th Apr 2018 2:58pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Black wolf .. will that mean you may have a mantec Raised Air intake for sale soon ?? Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #703095 25th Apr 2018 3:40pm
Grenadier
Went to give the Def a hose down, not a full wash, to remove a bit of rain sand marks. Got a bit distracted by a small area only for the timer to finish and me discover I was out of coins. I now have a half clean, half sandy Def. Fool. Whistle Monsieur Le Grenadier
Post #703097 25th Apr 2018 3:45pm
ericvv
Delivered it at the dealer this morning for the greasable hinges installation. Curious to see the result when I pick it up again tomorrow.
BTW - Just got an e-mail from a UK based supplier who also has those same greasable hinges added to his assortment now. Gareth Williams from Defender Upgrades. Maybe of use to some on here.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #703102 25th Apr 2018 4:10pm
L110CDL
GREENI wrote:
@clayton, I know she's your workhorse, though it looks like a bit of paint on the cage would be welcomed Razz
Yes i have looked at that a lot lately and i have seen a few painted and imo it does not look right, so the plan is in the future when the cage has to come off for some reason, i will get the whole lot shot blasted, then galvanised and then powder coated, but at the moment, i will call it patina as williamthedog has pointed out Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #703185 25th Apr 2018 8:41pm
Nice trip up to Hereford area today, across to Malvern and past Eastnor Castle Land Rover Experience. (Just drove past).
Nr Worcester and then back down south.
Weather pretty good too. Mr. Green $W33T $0U7H3RN $UG4R
Post #703204 25th Apr 2018 9:33pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I’ve just purchased some terrafirma TF705 lights for my A bar.
Is it possible I could wire them into the same switch as my light bar that comes on with the full beam, or would it have to be a separate switch, again to come on with the full beam?
Also got a NAS LED reverse and fog light to fit which should be easier.
Post #703212 25th Apr 2018 10:03pm
Yes, I suppose so. It's the metal kind, reasonable condition, as seen below. Are you interested? Drop me a pm if so.
Post #703216 25th Apr 2018 10:24pm
