Home > Maintenance & Modifications > Headling help please |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2034 |
I have one extra fir tree clip in my roof lining to help hold it up. It's been ok since this was added.
25th Apr 2018 12:22pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 453 |
Hi, thanks for the reply.
Is your extra one in the rear section then, running along the centre line from the front to the back? Mine are all coming out on the joing between the two sections, so I am thinking I need a more permanent fixing solution? Cheers. |
25th Apr 2018 12:27pm |
Yes, extra one in the middle of the rear section running along the centre front to back.
25th Apr 2018 3:26pm |
PD1 Member Since: 15 Feb 2017 Location: Sandhurst Posts: 41 |
I've done the same and it works fine.
26th Apr 2018 6:37am |
Thanks chaps.
I had another go last night, gave the extra long ones a whack with a rubber malet and they seems to have gone in better. So i will see and if they still fail I will go down the more permanant route! Cheers. |
26th Apr 2018 8:32am |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
Rubber mallet.... tap ‘em in.
1st May 2018 4:58pm |
Same here, 3 long ones, every other one... works fine. |
Cheers chaps,
the gentle persuasion of the mallet seems to have done the job for now! Cheers. |
1st May 2018 5:25pm |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 |
If they are pulling them selves out under gravity / roof lining weight try "packing" out the fir trees with a bit of heat shrink tubing WHAT COULD POSSIBLY GO WRONG
My sky lantern petition http://chng.it/HJXmZC47 |
1st May 2018 7:44pm |
