Home > Puma (Tdci) > PUMA 2.4- black smoke out of exhaust when accelerating
tcminto
Hi,
New to the forums and have got a 57 plate 90 which runs and pulls brilliantly. No issues when idle and no lack of power.
Noticed lots of black smoke from the exhaust when accelerating through 3rd/4/5th. Smoke does reduce once through.
I'm the third owner and fairly sure there has been a re-mapping in the past, according to the dealer I purchased from.
Any easy fixes/or issues with previous re-mapping that can be dealt with on the driveway before £££ at a specialist garage?
Cheers. Tom
Post #702593 23rd Apr 2018 3:49pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
The first thing is to get a diagnostic check and investigate any fault codes thrown up.
Be lucky Thumbs Up
Oh and welcome to the forum.
Post #702597 23rd Apr 2018 4:02pm
tcminto
Thanks very much.
Service and MOT were done last week with no advisories....
Is this something that should have been picked up then?
Post #702608 23rd Apr 2018 4:20pm
shropshiredefender
Depends on whether the service included a diagnostic check.
Post #702611 23rd Apr 2018 4:24pm
Cupboard
That a pretty common feature of the worse quality or more powerful remaps.
Black smoke is fuel that isn't fully burnt. It shouldn't be there, it's costing you money and some people think it looks cool.
I've been on holiday with a few remapped cars from three major Land Rover tuning companies (Alive, BAS, Storm) over both TD5 and Puma, they've all smoked badly when accelerating up a hill and that's not something I want out of my car.
It's not like people need any more encouragement to hate 4x4s, a face full of black smoke is hardly going to help matters.
Post #702615 23rd Apr 2018 4:40pm
shropshiredefender
A quality remap should not over fuel to the extent of producing black smoke IF the engine and associated emission control systems are all working properly - hence the suggestion of a diagnostic check.
Post #702617 23rd Apr 2018 4:53pm
Mine doesn't smoke..
Over fuelling is typically the issue, and often comes from backstreet tuners where people want a cheap 'chipping' style or 'tuning box' remap instead of paying for a quality premium service tuner. WeWillWin🇬🇧🇺🇸
Post #702624 23rd Apr 2018 5:42pm
zsd-puma
Visually checking that your garage changed the air filter when they serviced it would be a worth while move too.
My BAS remap give a black haze out of the exhaust when you have it flat out on the motorway.
Post #702750 24th Apr 2018 12:30am
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Just a few ideas, I'd be looking at fuel pump metering valve (vcv), injectors or egr of you are getting a lot of smoke.
Post #702836 24th Apr 2018 1:41pm
tcminto
Thanks for all the suggestions.
Will make a start at the air filter, injectors etc until I can get it in for a diagnostic check.
Pain in the a##e given I only bought it last week!
Post #702856 24th Apr 2018 3:42pm
When was the MAF and Map sensors last cleaned? WeWillWin🇬🇧🇺🇸
Post #702887 24th Apr 2018 5:38pm
Fernando
Argentina 2008 Defender 110 Puma 2.4 SW Bonatti Grey
I would go in this order, valve EGR and then VCV
regards
Post #703073 25th Apr 2018 2:07pm
ickle
Get a egr blank plate, they're only a few quid and easy to fit it will isolate the egr and any problems with it but will throw a fault code unless you have a egr close map put on.
Keith
Post #703267 26th Apr 2018 10:21am
NickMc
Can you not Take it back to the dealer if you only bought it last week?
Diagnostics should cost around the £45 mark.
Post #703392 26th Apr 2018 8:53pm
