Home > Maintenance & Modifications > Aircon grill refurb suggestions
CarMan
As you can see mine is a little scruffy - it has only just occurred to me, but I don't suppose this would a corrosion warranty item?
If not, then what's the bets way to fix?
I have previously replaced just the grille with a Naka one which worked well and I'd be very happy to do again, but of course it doesn't fix the bit below it.
So, what's the best long term solution Question
 Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #702173 21st Apr 2018 4:26pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
A forum member was making stainless ones a while back, (Mal) but he’s not on here anymore,
I brought one from ZunSport in Black Bentley style mesh,
But I also brought the grille to match which did prove a costly exercise Shocked
https://www.googleadservices.com/pagead/ac...amp;adurl= 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #702175 21st Apr 2018 4:31pm
Fifth Horseman
First time I managed to get mine replaced under warranty, second time I got a stainless one powder coated in black.
Plenty available online - google "defender aircon mesh stainless"
or forum sponsor 4x4Overlander sell the Nakatanenga one http://www.4x4overlander.com/product/defen...stainless/
Post #702181 21st Apr 2018 4:49pm
CarMan
Thanks guys, but I made not have made my self completely clear - not unusual Confused
The piece under the grill seems to stain and/or corrode as well, especially around the rivets, so I'm not sure replacing just the grille solves the problem completely Question
Post #702183 21st Apr 2018 4:54pm
UtilityTruck
I can’t find the link now, but nakatenenga do replacement ss inserts for the grill. They look fairly good as the pattern of holes matches closely- but it has the (imho) naff bear icon in each corner.
Edit, you just drill out the rivets and bolt them in place. 2014 Keswick Utility 2.2
Post #702184 21st Apr 2018 4:59pm
Fifth Horseman
With aluminium corrosion (which both the grill and rivets are made of) its not unusual for the surrounding paintwork to get stained. The gill surround is fibreglass or a similar composite so will not corrode. When I replaced my grill with a stainless one I used stainless dome head bolts to secure it after cleaning the paintwork with T-cut - no corrosion or discolouration after that.
Post #702185 21st Apr 2018 5:00pm
discomog
Brendan sells Nakatanenga ones in stainless steel, either natural finish or black. i decided on natural finish. My 90 is still under warranty but I decided to splash some cash rather than claim under warranty for JLR to fit another grille that would corrode within the next two years.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #702186 21st Apr 2018 5:06pm
CarMan
Good point, think I will go that way, to keep the oem look, but possibly in black Thumbs Up
Post #702196 21st Apr 2018 6:06pm
Zed
Mine is starting to look a bit tatty now. Just trying to decide between Nakatanenga or Zunsport.
Does anyone have a photo of the Zunsport lower with standard grille?
Post #702198 21st Apr 2018 6:10pm
Sulisuli
Because I have the KBX grill and headlight surrounds I opted to fit the KBX lower grill.
Had the original replaced under warranty but it’s only a matter of time before the replacement goes the same way Sad 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #702207 21st Apr 2018 6:41pm
CarMan
Looks really great, but not sure if it would work without KBX grille?
I can feel another 4x4overlander spend coming on, as I love the Zunsport option, but I am keen to stay kind of oem with a modern twist Neutral
Post #702211 21st Apr 2018 6:46pm
Sulisuli
Must admit without the KBX grill it probably wouldn’t work. Brendan will be happy to help you Thumbs Up have to totally sing his praises, great products, great service and probably the best customer service I have experienced anywhere in a long time Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #702240 21st Apr 2018 8:43pm
zsd-puma
I've got a britpart stainless lower grill on mine fits fine. The staining around the old rivets will polish off with some t-cut of similar.
I got some domed stainless Allen bolts instead of riveting it.
Post #702255 21st Apr 2018 10:34pm
CarMan
Now I do want black and I don't want to be tight @rse here but:
On a well known on-line auction site I have seen:
Powder coated ali grill including stainless fixings for £30
Powder coated stainless grill with no fixings also for £30
Whereas the Naka option is £57 + p&p I think and without fixings as far as I can see.
I'm guessing the fixings wouldn't be expensive but are there good reasons why stainless is a better option than ali Question
Post #702399 22nd Apr 2018 4:40pm
discomog
Similar to zsd-puma, I used torx machine screws instead of those poxy rivets. Defender 90XS SW
Morgan Plus 8
Post #702418 22nd Apr 2018 5:47pm
