Home > Technical > Blank air intake |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 148 |
That's the main reason I haven't upgraded to KBX, can't see the point of forcing more water in as you drive along in the rain.
16th Apr 2018 8:16pm |
it's crazy they don't supply a flat piece of plastic to sandwich behind the disused one. You could always cut one to shape from a piece of ice cream tub or similar.
That being said it won't do any harm having it open. If you look at the edge of the bonnet right next to it, there's nothing there to keep the water out. |
16th Apr 2018 11:52pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Will water come in or would warm air get out? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
17th Apr 2018 5:39am |
TonvanB Member Since: 29 Jan 2018 Location: Leiden Posts: 4 |
Thanks! I am only worried about the "spongy thing" which es probably a piece of insulator but I have to find out. But I probably would use put a piece of plastic to close the inlet |
17th Apr 2018 6:42am |
Both I guess but I don't which one wins |
17th Apr 2018 6:43am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17376 |
I think that the "sponge thingy" is the rather pathetic acoustic binbag that certain models had fixed to the plastic inner wings, in which case it is already disintegrating. It should be thin foam encased in a plastic thing rather like a black bin liner. I don't think it actually does anything useful except retain water and dirt, and eventually disintegrate and fall off in little pieces! |
17th Apr 2018 10:26am |
Thanks , waste so to say!
18th Apr 2018 3:24pm |
