Home > Technical > Intermittent wiper going to normal speed
VVS210
MY02 Td5
When in intermittent mode my wipers will work fine for a variable period of time then without any change to the stalk setting will suddenly go into normal mode. Turning off then going back to intermittent they go straight to slow mode.
Thought this might be the switch as it was past its best but having replaced with a new genuine parts one, & initially thinking the problem was cured, the fault is still there.
What should I look for next? I am thinking replacing the intermittent relay?
Cheers.
Post #700176 11th Apr 2018 12:10pm
rallysteve
I would change the relay if i was you. I have a working spare if you want it?
Cheers,
Post #700178 11th Apr 2018 12:14pm
VVS210
Thanks Steve, that's a very kind offer, PM to follow. Cheers.
Post #700183 11th Apr 2018 12:42pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Mine does the same thing, tried a new relay to no avail. Sad
Post #700435 12th Apr 2018 7:47pm
VVS210
^^^^ have you replaced the switch on yours?
Post #700463 12th Apr 2018 9:16pm
miker
Park switch?
My wipers never do intermittent, and I know my park switch is dead (as they don't park, they just stop)
Post #700470 12th Apr 2018 9:41pm
mrd1990
My park switch is working, I have not yet replaced the column switch as I was hoping to someone else would say they tried that first.
Mine would sometimes go on intermittent for a while then would just go normal speed, up until a few months ago. Now it is normal speed all the time.
I suspect the issue could be corroded wires somewhere behind the dash, possibly the earthing on the relay, or the relay being bypassed altogether.
Post #700501 13th Apr 2018 7:42am
bluebottle
I’d get the switch out and put a multimeter on it - see if something’s shorting or not switching properly first.
Hopefully it’s your relay, then you can use it as an excuse to put a programmable variable intermittent one in. Best of luck!
Post #700511 13th Apr 2018 8:25am
