Home > Puma (Tdci) > DCPU Owners, am I high?
Page 3 of 3 <123
Grenadier
mk1collector wrote:
Surely the rolling radius of an 18" wheel and tyre should be roughly the same as a 16" wheel and tyre so won't make the arch gap any different?
Would they? How would that work? Large wheel=larger tyre=large radius, surely? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #700192 11th Apr 2018 2:35pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Find out here: https://tiresize.com/tyre-size-calculator/
Post #700198 11th Apr 2018 3:10pm
mk1collector
The tyre wall is smaller to compensate for the bigger wheels so your speedo reads the same. Ray
My build thread
Post #700207 11th Apr 2018 3:38pm
Grenadier
Christ I'm dim sometimes Embarassed Monsieur Le Grenadier
Post #700216 11th Apr 2018 4:46pm
mk1collector
Rolling with laughter don't worry I'm dim most of the time Rolling with laughter Ray
My build thread
Post #700232 11th Apr 2018 5:47pm
CarMan
hank wrote:
zsd-puma wrote:
If you go onto topix and look up your build sheet from the VIN, it should state whether HD springs were fitted.
Failing that you'll have to get under there with a torch and try to find the colour codings.
Good tip!! What am I looking for to identify whether HD springs have been fitted? I can see on my build sheet it says: 4200 LB(1909 KG) REAR AXLE ASY
Mine says this: HVY DUTY SUSP L316 (DNU)
But you can identify from the coloured markings on the springs if you can see see them of course and compare to the chart earlier in the thread Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #700239 11th Apr 2018 6:16pm
Grenadier
Tried to have a look, but winter grime prevents me. It'll be going for a deep clean soon, can take a peek after.
For those DCPU owners who have the lift (which seems to be the consensus amongst us that mine has) do you bounce around a lot? As mentioned in my OP, she strangely handles like an absolute dream, better than any Def of any age/type/variety I have ever driven. Note, I have never driven a fast-road suspension version with Bilsteins, upgraded ARBs, lowered springs etc, that is yet to come, but as a stock Def goes she's a blast. But when driving along a straight, at some speed (perhaps 70mkh+) she doesn't half bounce around in the rear when going over gentle rolls in the road, gutters, tarmac changes etc. Monsieur Le Grenadier
Post #700324 12th Apr 2018 9:26am
Roy5695
The bouncyness comes from the HD aspect of the springs, load 3/4 ton of crap in the back and it will drive like an absolute dream! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #700327 12th Apr 2018 9:34am
Intercept
Removing the lift from mine reduced the cornering roll - it doesn't have ARBs (yet). I don't consider it to be bouncy - that would suggest damper issues.
Post #700381 12th Apr 2018 3:17pm
mick
As Roy said it’s a weight carrier my 130 is loaded all the time and it’s a real nice ride on any surface.
Post #700384 12th Apr 2018 4:00pm
zsd-puma
Reducing the rear tyre pressures when empty also helps a bit.
Post #700409 12th Apr 2018 6:30pm
Grenadier
Don't get me wrong, it does handle like a dream, but as mentioned previously if I go over, for an example, a change between tarmac, 90kmh, straight line, there's a definite bounce from the rear for a couple of revolutions. Anyway, it's all moot, as new springs AND new dampers are coming soon and should sort out the ride, the look, the height etc Thumbs Up Monsieur Le Grenadier
Post #700417 12th Apr 2018 6:52pm
Page 3 of 3 <123
