Home > Maintenance & Modifications > sump removal TD5 strange finding |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
CLip to hold the clutch fork in place
9th Apr 2018 12:01pm |
defsan Member Since: 18 Jan 2018 Location: South Holland Posts: 13 |
Oh wow many thanks!
It seems that I am unable to check it without removing the gearbox and flywheel, am I correct? Do you know the purpose of the item and can do I without safely? Did not have any trouble driving, so maybe an old one? thanks! |
9th Apr 2018 12:33pm |
Number 11 in the below image; FRC2975
Click image to enlarge To check you will need to split the bell housing from the engine and would make a good time to check the rear output seal, clutch and flywheel |
10th Apr 2018 9:12am |
It must be a spare one, surely? It can't have fallen into the sump from inside the bellhousing?? Darren
10th Apr 2018 9:19am |
MaxRPM Member Since: 15 Jan 2013 Location: South Staffs Posts: 1114 |
OP said it was found in the bell housing
10th Apr 2018 11:07am |
Ah, my mistake! Darren
10th Apr 2018 11:43am |
Thanks all for thinking with me! I have found a clear image on how the item is fixed and it seems that it is crucial in keeping the fork in the proper place.
I have ordered a small flexible camera to look behind the flywheel, with a little luck the item is still on and I dont have to remove the clutch and gearbox. Fingers crossed. Is there a simple way to replace the clutch? On the net I can find only the two following possibilities. - remove all interior flooring and use a crane inside the car to move the gearbox after removing crossmembers / handbrake - remove or turn the engine using a crane Both seem like quite a lot of work for replacing the clutch. many thanks. |
10th Apr 2018 1:24pm |
I must admit I read it that way first time around too. |
10th Apr 2018 6:24pm |
Checkend with the camera, item is not there but the clutch is firm in place.
Will take the risk and leave it now untill the next clutch replacement. thanks for the info guys! |
16th Apr 2018 3:20pm |
