Home > Maintenance & Modifications > sump removal TD5 strange finding
defsan
Netherlands 2007 Defender 110 Puma 2.4 SW Java Black
Dear all,
many thanks for the great forum and wealth on information!
Currently I am in the process of building our overland Defender and doing relatively simple tasks myself.
I read on the internet about the dreaded TD5 oil bolt and figured we would not like to be stuck somewhere in the desert because of this easy to fix problem.
Removed the sump etc etc, the only thing is I have found a strange item in the flywheel housing
Its a 4x4cm item which was found near the square drain plug on the bottom of the housing(inside).
Does any of you pro's have an idea what this could be? I have not been able to track it down and I am very curious about what this could be.... Shocked Shocked Shocked
Many thanks.
Post #699554 9th Apr 2018 12:32pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
CLip to hold the clutch fork in place Thumbs Up
Post #699559 9th Apr 2018 1:01pm
defsan
Oh wow many thanks!
It seems that I am unable to check it without removing the gearbox and flywheel, am I correct?
Do you know the purpose of the item and can do I without safely? Did not have any trouble driving, so maybe an old one?
thanks!
Post #699564 9th Apr 2018 1:33pm
geobloke
Number 11 in the below image; FRC2975
To check you will need to split the bell housing from the engine and would make a good time to check the rear output seal, clutch and flywheel Rolling Eyes
Post #699790 10th Apr 2018 10:12am
It must be a spare one, surely? It can't have fallen into the sump from inside the bellhousing?? Darren
Post #699792 10th Apr 2018 10:19am
MaxRPM
OP said it was found in the bell housing
Post #699822 10th Apr 2018 12:07pm
Ah, my mistake! Darren
Post #699827 10th Apr 2018 12:43pm
defsan
Thanks all for thinking with me! I have found a clear image on how the item is fixed and it seems that it is crucial in keeping the fork in the proper place.
I have ordered a small flexible camera to look behind the flywheel, with a little luck the item is still on and I dont have to remove the clutch and gearbox.
Fingers crossed.
Is there a simple way to replace the clutch? On the net I can find only the two following possibilities.
- remove all interior flooring and use a crane inside the car to move the gearbox after removing crossmembers / handbrake
- remove or turn the engine using a crane
Both seem like quite a lot of work for replacing the clutch.
many thanks.
Post #699851 10th Apr 2018 2:24pm
zsd-puma
LandRoverAnorak wrote:
Ah, my mistake!
I must admit I read it that way first time around too.
Post #699963 10th Apr 2018 7:24pm
defsan
Checkend with the camera, item is not there but the clutch is firm in place.
Will take the risk and leave it now untill the next clutch replacement.
thanks for the info guys!
Post #701275 16th Apr 2018 4:20pm
