Home > Technical > 110 TDCi Front Axle - Same as other marques?
hank
The nearside front spring seat has collapsed on my 110. The inner vertical 'leg' has bent resulting in the horizontal spring seat no longer being horizontal
The spring seat does not appear to be serviceable as it is welded on so I am looking to replace the axle casing
Are TD5 axle casings interchangeable or do I specifically need a TDCi one?
Post #699563 9th Apr 2018 12:28pm
Lotus_esprit_s1
You can buy replacement weld on brackets, £7 or so each. Takes ten minutes to cut old one off and weld on new one, can be done with axle in situ if you remove spring. I did the above last month.
Post #699609 9th Apr 2018 4:18pm
V8GPC
You could cut off the item and buy a nice new one to weld on from YRM
https://yrmit.co.uk/product-category/land-...uspension/
£8 +VAT, and only 1-2hrs labour (locally) if you can't do it yourself. Less time and £££ than a total axle replacement.
Post #699610 9th Apr 2018 4:21pm
hank
Brilliant! Thanks both
Is this a common issue then?
Post #699650 9th Apr 2018 6:51pm
Retroanaconda
Not on a vehicle as young as yours.
On old Land Rovers it’s not uncommon as they eventually rust or the damper pin wears the hole into an oval.
Post #699665 9th Apr 2018 7:17pm
Lotus_esprit_s1
Depends on where you live... the photo above is a 2007 tdci, all four were rotten.
Post #699709 9th Apr 2018 8:25pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Was the TDCi used by or in the Sea? Confused Working towards Carry on camping!
Post #699715 9th Apr 2018 8:48pm
hank
No it's spent its life inland really. The other three seem fine but will inspect again on the weekend
Hopefully my trusty Clarke 150 amp is man enough for the job
Post #699813 10th Apr 2018 10:36am
