Home > Td5 > Power problems in rain
Page 2 of 2 <12
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Be good to check all the hoses along the intake. There is a flex hose behind the engine just under the fuel pressure regulator. When the FPR leaks (as thry all will) it diissolves the rubber nad causes a big air leak and water ingress issues into the air cleaner box. Good luck. 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #699411 8th Apr 2018 4:11pm
Kst80
Cheers, will do. As luck has it I’ve just had a new FPR.........it’s like a jigsaw! Laughing
Thanks again.
Kev
Post #699460 8th Apr 2018 8:44pm
isacs
I was under the impression the plastic jobby RAI had a habit of sucking in spray while driving on motorways etc
Post #699479 8th Apr 2018 9:35pm
Kst80
Is that through the actual air intake or via the wing seal? This is where the 300 we had was sealed by its previous owner.
Post #699500 8th Apr 2018 10:56pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
If you have the air intake pointing forwards, yes, it will get water in it and for whatever reason the TD5 air filter seems particularly prone to issues with the air filter getting damp. Pointing the air intake backwards will help reduce water intake, especially from spray on motorways etc... http://www.yorkshireoffroadclub.net/
Post #699503 8th Apr 2018 11:10pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I have both the problems mentioned, in the wet it hicups unless the safari style head is reversed, and I alos suffer with the damp right foot at times too! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #699508 9th Apr 2018 12:20am
Kst80
In a twist, had problem again today. Again about 55/60 mph drove 30 miles no issues parked up for 4 hours set off again, temp guage up to normal and again it stuttered. Driven it since without issue. Nice sunny day (could be not used to warming sunny weather Laughing )
Checked air filter and it’s still dry.
Thanks again for all advice.
Kev.
Post #699716 9th Apr 2018 9:52pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Check maf sensor plug and intake sensor plugs spray some wd40 or olivine grease aroudn connectors and try that
Also check intercooler hose to intake manifold is tight with no leaks
Also check ecu is not getting damp under driver seat box plug the drain holes in each corner
I’ve seen all the above happen and cause the symptoms 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #699728 9th Apr 2018 10:22pm
mk1collector
Check ecu red plug for oil, if there's oil there you'll need to change the injector loom. You could also try unplugging the maf and driving about for a bit, if there's more power with it unplugged you need a new one. Ray
My build thread
Post #699731 9th Apr 2018 10:27pm
geobloke
Sounding more like a wiring issue now. Check engine loom for rubs and frays, especially where the loom wraps around the engine and over the bell housing.
Frayed wiring shorting on the engine or on other wiring could cause intermittent running issues.
Post #699791 10th Apr 2018 10:15am
gazman
I forgot to mention. I had a issue with the connection in the tx box on mine that caused the throttle to change from high to low range throttle map and back again when wet or damp. It used to cause hiccups as it switched 2014 - current ..... 2003 defender td5 90 (my car)
Post #699848 10th Apr 2018 2:04pm
Kst80
tried unplugging MAF and it does appear to have more power, run better and even sound a bit better. Other bits and red plug seem okay.
Is a genuine part worth the extra or not does anyone know?.
Thanks again for all the help much appriciated.
Post #699862 10th Apr 2018 3:21pm
Clean the MAF by blowing brake cleaner through, don’t touch the sensor and let it thoroughly evaporate and dry.
If nothing else, it should help. WeWillWin🇬🇧🇺🇸
Post #699863 10th Apr 2018 3:23pm
Kst80
Took MAF off and it looks very clean, including the sensor inside.....or is it.
Should it look dirty or am I missing something?
Do I just spray the sensor anyway?
Sorry but I want to go cautiously........I have some brake cleaner handy though!
Thanks again
Post #700242 11th Apr 2018 6:45pm
mk1collector
If you go on the bas tuning site it shows you how to check if the maf is working with a multimeter. If I get power back when mines unplugged I just swap it out for a new vdo one. Ray
My build thread
Post #700244 11th Apr 2018 6:55pm
Page 2 of 2 <12
