Home > Puma (Tdci) > Changing piston cooling jets
Erik256
Estonia 2007 Defender 110 Puma 2.4 SW Keswick Green
Hi
Does anybody know (or knows somebody who knows) if the piston cooling jets can be changed by only removing the sump or does the crankshaft needs to be removed as well?
Asking this as I'm always been paranoid about developing the PCJ issue, since my car is one of the early ones. Although for now the engine seems to work fine, aside from very slight ticking when the engine is cold, I would change the jets if the work could be done without removing the crankshaft.
Thanks
Post #698754 5th Apr 2018 3:59pm
I believe that the sump and the ladder frame stiffener thingy need to be removed and I have a feeling that the latter cannot be be done with the engine in the vehicle. I don't know this from first hand experience though and may be mistaken.
I'll be interested to see what other replies you get.
Post #698758 5th Apr 2018 4:40pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Looks tight without removing the Crankshaft! Sad
No other useful info that I can see in the manual though.
Post #698814 5th Apr 2018 8:23pm
zsd-puma
Looking at those pics I'd say it's possible, although you'd need to rotate the crank to get access to each one.
Post #698858 5th Apr 2018 11:32pm
Erik256
Thanks everybody for sharing your thoughts. I took another look at the manual and I think that Blackwolf is right in that the ladder fame has to come off as well. I also first looked at the picture that BenB8man shared, that got my hopes up, that perhaps the change can be done by simply removing the sump and rotating the counterweights out of the way, but it seem that the ladder fame has an oil baffle plate that is the way.
Post #698866 6th Apr 2018 5:35am
Merlin
There was a recall on this in about 2008. It said remove assembly and fit new. Merlin
Post #699023 6th Apr 2018 5:50pm
The recall replaced the whole engine, not the PCJs, because you only found out you had faulty PCJs when your engine destroyed itself.
It wasn't actually a recall anyway because you only got a new engine if (1) your engine was destroyed as a result of the defective PCJs and (2) you asked for one and (3) both 1 and 2 happened before a cut-off date (which was 2011 or 2012 if memory serves). Otherwise you ended up paying many thousands for a new engine yourself.
Sadly typical of JLR.
Post #699024 6th Apr 2018 5:55pm
