![]() | Home > Puma (Tdci) > Changing piston cooling jets |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17608 ![]() ![]() ![]() |
I believe that the sump and the ladder frame stiffener thingy need to be removed and I have a feeling that the latter cannot be be done with the engine in the vehicle. I don't know this from first hand experience though and may be mistaken.
I'll be interested to see what other replies you get. |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 431 ![]() ![]() ![]() |
![]() Click image to enlarge Looks tight without removing the Crankshaft! ![]() No other useful info that I can see in the manual though. |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Looking at those pics I'd say it's possible, although you'd need to rotate the crank to get access to each one.
Erik256 Member Since: 05 Mar 2013 Location: Tallinn Posts: 26 ![]() ![]() ![]() |
Thanks everybody for sharing your thoughts. I took another look at the manual and I think that Blackwolf is right in that the ladder fame has to come off as well. I also first looked at the picture that BenB8man shared, that got my hopes up, that perhaps the change can be done by simply removing the sump and rotating the counterweights out of the way, but it seem that the ladder fame has an oil baffle plate that is the way.
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
There was a recall on this in about 2008. It said remove assembly and fit new. Merlin
The recall replaced the whole engine, not the PCJs, because you only found out you had faulty PCJs when your engine destroyed itself.
It wasn't actually a recall anyway because you only got a new engine if (1) your engine was destroyed as a result of the defective PCJs and (2) you asked for one and (3) both 1 and 2 happened before a cut-off date (which was 2011 or 2012 if memory serves). Otherwise you ended up paying many thousands for a new engine yourself. Sadly typical of JLR. |
