Home > Maintenance & Modifications > Upgraded washer jets & pump |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
This might help
http://www.defender2.net/forum/topic34027....heated+jet |
2nd Apr 2018 7:27pm |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Thanks - that was actually part of my motivation for the idea, just not sure that the existing pump will be up to the job based on its performance with the current set up...
2nd Apr 2018 7:32pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
I fitted Ford Focus heated washer jets on my bonnet std pump was fine but be sure to fit a non return valve in the pipe otherwise they take to long to work when you need them 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
2nd Apr 2018 8:13pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 629 |
I doubled up on the original jets fitted into the spare wiper holes. Got excellent performance from this. This is with original pump. So if yours is poor already I would plan on replacing it when you change the jets. 1995 Defender 110 CSW
1971 SIIA Lightweight |
2nd Apr 2018 9:26pm |
If money is no object there is always these.
http://optimillraceproducts.com/product_info.php?products_id=135 Ray My build thread http://www.defender2.net/forum/topic17615.html |
2nd Apr 2018 10:15pm |
^^^^ think I'll swerve that one!
2nd Apr 2018 10:32pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Out of stock anyway !
Forgetting nozzles for a minute - does anyone know if there is a direct replacement, upgraded, plug and play pump available to increase flow rate ? 2007 TD5 90 Hard Top Last edited by Landlord on 3rd Apr 2018 6:58am. Edited 1 time in total |
2nd Apr 2018 11:02pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Pity DDE don’t have a heated version of their washer jets, look nicely made.
http://www.designdevelopmenteng.co.uk/stor...-p90670813 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
3rd Apr 2018 6:22am |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
I have a dual setup on my 2008 puma.
The original pump is more than adequate for this set up. My nozzles never get frozen but i do use quality screenwash i believe to -30 degrees Last year i’ve fitted the heat shot. Excellent piece of kit. In the winter the front screen is quickly defrosted and in the summer it get rid of all the bugs Or at least most of them. So if you OWN a puma there could be another problem. Dying pump Or perhaps Some clogging somewhere? On my puma i’ve got 2 pumps for front and rear. I see no (technical) problem to use them both for the front. Or split the passenger side with the back one. Bus as i have said on mine it works great a defender from 1984 pretending to be a puma with a touch of Range Rover |
3rd Apr 2018 7:08am |
Blackwolf recently showed how he'd fitted a bigger pump from a Disco2 to his washer bottle with a machined adapter from, I think, Optimill. This was to serve headlight washers but the principal would be the same for screen washers. However, I'm pleasantly surprised how powerful the washers are on my recently acquired Puma so, as others have said, you may have a problem with your pump. Darren
3rd Apr 2018 8:18am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17468 |
All the pressure you could possibly want. TDCi twin pump reservoir fitted with (on the left) a Disco2 type headlamp washer pump for the screenwasher, and (on the right) a Rover 45 headlamp washer pump for the headlamp washers. These pumps are identical apart from the outlet angle and the Rover 45 pump is used to allow clearance for the hose to pass the lower-mounted Disco pump (lower-mounted so the headlamp washers run out before the screen washers). The mounting hardware for the pumps was supplied by Optimill. The pumps are fitted with the correct quick-release connectors (ex-Disco2) for the hoses.
3rd Apr 2018 8:45am |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
This is what I've had on my 90 since I bought it nearly 20 years ago with no problems! I've often wished I could easily fit heated jets (I fitted heated D3 jets to my D2 with great effect!) but reckon I'd have to fit them nearer the front of the bonnet so as to get them to reach the screen! A TDci bonnet would help here though.The extra distance would, I think, dratically reduce their effectiveness and look a bit daft too. There is, I believe, a heated washer pump set up on the market which looks great but I think it's quite pricey! |
3rd Apr 2018 3:57pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5111 |
Sometimes the brass tiny holes in the housing become blocked particularly if you live in a hard water area. Before you, do anything just poke a sewing needle down the jets in case they have become clogged. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
3rd Apr 2018 7:17pm |
Alex2000 Member Since: 23 Mar 2020 Location: North Yorkshire Posts: 9 |
what type of connector is the rover 45 pump tying to find one for my pump and wjat type of connector is the disco 2 one as well? |
24th Feb 2023 6:35pm |
