Home > Maintenance & Modifications > Upgraded washer jets & pump
Page 2 of 2 <12
Both pumps use the same type of connector but I cannot presently remember where I bought the connectors I'm afraid.
Post #983569 24th Feb 2023 8:14pm
Alex2000
would any electic shop have them like yes electrical?
Post #983572 24th Feb 2023 8:49pm
Martin
Site Admin
https://www.defender2.net/forum/topic58137-15.html?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #983575 24th Feb 2023 9:18pm
Thanks for the link and memory-jog Martin.
As you say they are Econoseal 250 Series connectors, and my records show that I bought them from Simtek. My records also show that I have several spares but I have no idea where I have put them!
It is a little disturbing that they appear now to be five times the price that they were in 2017. Shocked
Post #983580 24th Feb 2023 9:36pm
TransientWolf
United Kingdom 1991 Defender 90 200 Tdi CSW Corris Grey
blackwolf wrote:
All the pressure you could possibly want. TDCi twin pump reservoir fitted with (on the left) a Disco2 type headlamp washer pump for the screenwasher, and (on the right) a Rover 45 headlamp washer pump for the headlamp washers. These pumps are identical apart from the outlet angle and the Rover 45 pump is used to allow clearance for the hose to pass the lower-mounted Disco pump (lower-mounted so the headlamp washers run out before the screen washers). The mounting hardware for the pumps was supplied by Optimill. The pumps are fitted with the correct quick-release connectors (ex-Disco2) for the hoses.
Hi. Sorry to resurrect after so long but wondered if you used the original wiring given higher power pumps or ran new wiring and a relay? Thanks.
Post #1009249 28th Sep 2023 12:18pm
I seem to remember that I used the original wiring to activate two relays, which are fused directly from the battery. I installed a bank of relays just inside the n/s wing which are individually fused from the battery and use sensible gauge wiring. The relays operate the windscreen and headlamp squirters, the headlamps themselves (dip/main), the light bar on the front of the rack, and the amber strobes and beacons on the rack, and possibly a few other things I have temporarily forgotten.
It is very easy to install and configure relays for the squirters and headlamps in this area since they are so close to the original wiring and it is easy to cable back to the battery box. They are also high enough in the engine bay to avoid getting dunked in water or mud too often.
Post #1009250 28th Sep 2023 12:27pm
Alex2000
it wasn’t hard to make my own wiring
I used a relay from https://www.autoelectricsupplies.co.uk/p/1...-and-break
And this plug https://www.simtekuk.co.uk/product.php/250...:::1593614
think it’s the same as a disco2 one. And got a plug to go in the original wiper wiring and got power from battery for high power
Post #1009252 28th Sep 2023 12:29pm
It also helped me that the wiring for the rear screen wash/wipe was present on my double-cab, so much of the work for the headlamp washers was already done for me.
I think the later DCs had a value-engineered harness, but on my '07 the dash wiring and main harness wiring for the heated rear screen and rear wash/wipe were all present, which has proven very useful over the years for other things.
Post #1009258 28th Sep 2023 12:57pm
Page 2 of 2 <12
