Home > Tdi > Brake fluid warning light - MOT failure |
Click image to enlarge on later model |
2nd Apr 2018 9:16pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
It certainly is on Pumas. If the level is at the max mark, the light will flicker on if you brake going down a steep hill.
I keep my fluid at the base of the filler neck, a little above the max mark. I imagine earlier vehicles may have similar quirks. |
3rd Apr 2018 8:57am |
EuropeDefender Member Since: 02 Apr 2018 Location: Tuscany Posts: 11 |
Yes, the sender is really "too sensitive".
My '98 300 has the same light almost always on. It torns off only when you are completely stopped on a flat ground (and the level to the "max"). Si Vis Pacem Para Bellum |
3rd Apr 2018 11:44am |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 |
Thanks guys.
The flashing light really is quite annoying but if it's "normal" I'll live with it. Roy 300tdi 90 1996. |
10th Apr 2018 9:53pm |
You can "fix" it disconnecting one of the wire from the sender, and checking level once a month. Si Vis Pacem Para Bellum
11th Apr 2018 5:55am |
300tdi 90 1996.
11th Apr 2018 6:59am |
