Home > Puma (Tdci) > Swivels .. shimming |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1372 |
If the swivels have been "very loose" as you say, this won't have done the bearings any good.
Both top and bottom have been run with slack, so I'd say both will be worn and should be replaced. I don't know if you can do a full top bearing properly without stripping the hub? |
2nd Apr 2018 12:10pm |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 |
I’ve just done my swivels, the bearings were cheap even for timiken ones straight forward job if you take your time IMO. The resistance seems to be set much lower on the newer cars? The replacement top bearings were also much larger than the original ones fitted to my TD5...
2nd Apr 2018 2:44pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2615 |
You'll have to strip it down fully even to do one bearing unless you go for the pikey method and just swap one race leaving the other in the ball - don't do this as it will fail in a very short time.
As above a straightforward enough job. If your caliper pipe brackets are slotted you don't even need to bleed the brakes, but most aren't unfortunately. |
2nd Apr 2018 4:20pm |
Mine wasn't slotted, I just took the whole bracket off and moved it out the way didn't need to crack open any pipes etc.
2nd Apr 2018 4:24pm |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 698 |
Lol .. I suppose I was looking to see whether I could get away with a quick job, but you’ve answered that. I’ll strip down and rebuild 2008 Defender 110 XS SW - M57N2 / 6HP28X |
2nd Apr 2018 4:47pm |
