![]() | Home > Puma (Tdci) > Swivels .. shimming |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1467 ![]() ![]() ![]() |
If the swivels have been "very loose" as you say, this won't have done the bearings any good.
Both top and bottom have been run with slack, so I'd say both will be worn and should be replaced. I don't know if you can do a full top bearing properly without stripping the hub? |
TJH1985 Member Since: 22 Aug 2016 Location: Midlands Posts: 238 ![]() ![]() |
I’ve just done my swivels, the bearings were cheap even for timiken ones
![]() Last edited by TJH1985 on 2nd Apr 2018 4:23pm. Edited 1 time in total |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2735 ![]() ![]() |
You'll have to strip it down fully even to do one bearing unless you go for the pikey method and just swap one race leaving the other in the ball - don't do this as it will fail in a very short time.
As above a straightforward enough job. If your caliper pipe brackets are slotted you don't even need to bleed the brakes, but most aren't unfortunately. |
Mine wasn't slotted, I just took the whole bracket off and moved it out the way
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Lol .. I suppose I was looking to see whether I could get away with a quick job, but you’ve answered that. I’ll strip down and rebuild 2008 Defender 110 XS SW - M57N2 / 6HP28X |
