Home > Puma (Tdci) > Changing rear wiper blade on a 90
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Just wondering if I am missing something but is it possible to change the rear wiper blade on a 90 without removing the spare wheel?
I can undo the blade clip but can not slide the blade past the wiper arm as the tyre (265/75 16) is in the way and I do not want to bend/damage the arm. Cheers Don.
Post #697622 1st Apr 2018 12:12pm
Sulisuli
Tyre off I’m afraid Sad I have tried it without taking it off and haven’t found a way yet Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #697626 1st Apr 2018 12:19pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I spent a considerable amount of time trying to do this without removing the wheel but had to give in in the end and do it.
I did think maybe the whole arm could be removed with out removing the wheel but I did not pursue it. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #697636 1st Apr 2018 1:00pm
zsd-puma
Nope, you have to take the wheel off. But then again it's not exactly a big job to undo the three nuts and lift the wheel off. Chances are the back door will need a wash and polish behind there anyway.
Post #697659 1st Apr 2018 3:42pm
Another argument for a swing-away wheel carrier.
Post #697667 1st Apr 2018 4:37pm
grafty99
Turn the wiper on then switch the ignition off when it's in the upright position Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #697668 1st Apr 2018 4:39pm
Sulisuli
Thanks for the tip Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #697670 1st Apr 2018 4:41pm
TOP5N
GET THIS GUY A BEER !! so simple, but yet it never crossed my mind Laughing
Post #697691 1st Apr 2018 5:26pm
dgardel
Italy
Yes, as per grafty99 suggested or, in my case, with the Mantec wheel carrier you can change the blade without take off the wheel Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #697845 2nd Apr 2018 8:58am
discomog
it's called thinking outside of the box. Mr. Green Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #697850 2nd Apr 2018 9:21am
zsd-puma
Just tried it, it's still tight, but works a treat. Laughing
Post #698025 2nd Apr 2018 5:15pm
grafty99
1990 Vogue SE
Post #698942 6th Apr 2018 12:42pm
Nipalong
England 2015 Defender 90 Puma 2.2 SW Corris Grey
Well, I just change mine, no removing wheel or anything.
Post #699292 7th Apr 2018 8:42pm
