![]() | Home > Puma (Tdci) > Changing rear wiper blade on a 90 |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
Just wondering if I am missing something but is it possible to change the rear wiper blade on a 90 without removing the spare wheel?
I can undo the blade clip but can not slide the blade past the wiper arm as the tyre (265/75 16) is in the way and I do not want to bend/damage the arm. Cheers Don. |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 ![]() ![]() ![]() |
I spent a considerable amount of time trying to do this without removing the wheel but had to give in in the end and do it.
I did think maybe the whole arm could be removed with out removing the wheel but I did not pursue it. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Nope, you have to take the wheel off. But then again it's not exactly a big job to undo the three nuts and lift the wheel off. Chances are the back door will need a wash and polish behind there anyway.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
Another argument for a swing-away wheel carrier.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Turn the wiper on then switch the ignition off when it's in the upright position
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
Thanks for the tip
![]() 2008 SVX 90 2000 XS TD5 90 |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 ![]() ![]() |
GET THIS GUY A BEER !! so simple, but yet it never crossed my mind ![]() |
Yes, as per grafty99 suggested or, in my case, with the Mantec wheel carrier you can change the blade without take off the wheel Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
it's called thinking outside of the box. ![]() Mini Countryman Cooper S Morgan Plus 8 |
Just tried it, it's still tight, but works a treat. ![]() |
Nipalong Member Since: 08 Jul 2015 Location: Kent Posts: 29 ![]() ![]() ![]() |
Well, I just change mine, no removing wheel or anything.
