Home > Td5 > Diff and Transfer case oils
excossack
Going to change oils in Diffs and transfer case, Haynes book suggests:
Diffs: SAE80/SAE90EP to API GL4 / MIL-L-2105 or better
T/C: 75w90 to GL4 spec. Lots of places appear to do GL5 oils and I think the RAVE manual suggested GL5 spec.
Is GL5 spec of for both Diffs and T/C?
Spotted on Opie oils
Gulf Gear EP heavy duty G/Box oil 80w/90 for Diffs.
Fuchs Titan 75w90 for T/C 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #696735 28th Mar 2018 2:34pm
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
I am using Castrol syntrax Long Life 75W 90 in Diffs and Transfer box. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #696736 28th Mar 2018 2:40pm
X4SKP
Hello excossack
Castrol 75W-90... Thumbs Up
March 2017 Price
But in the end I went for Motul Gear 300 75W-90 for an all Transmission Oils change (10 Lts required)
I did this on the recommendations of Opie Oils, as the Motul looks to be a slightly higher spec' than the Castrol,
and qualifies as a Racing Oil.
March 2017 Price
So for a Puma (Getrag Gearbox MT82) / TD5 (R380 Gearbox)
Transmission ...
75W 90 / 3 x 1L
Transfer Box (LT230Q / Puma + TD5) + Front & Rear Differentials
75W 90 / 7 x 1L
Good Luck SKIP
Post #696742 28th Mar 2018 3:03pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I recently ordered from Opie castrol epx 80/90 for diffs and Castrol syntrans 75/90 for transfer box. Then lr mtf94 for main gearbox from different supplier on eBay.
Post #696748 28th Mar 2018 3:52pm
excossack
X4SKP wrote:
Hello excossack
March 2017 Price
March 2017 Price
Transmission ...
75W 90 / 3 x 1L
75W 90 / 7 x 1L
Good Luck
Cheers X4SKP, Motul is currently at £14.50 a litre. Pity its just 1L containers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #696782 28th Mar 2018 5:38pm
excossack
After a bit of hunting ended up with 5litre of Granville oil and 5litre of Croma oil. 1999 Defender TD5 110
Regards
John M0VAZ
Post #697025 29th Mar 2018 6:33pm
