Home > Td5 > Diff and Transfer case oils |
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 |
I am using Castrol syntrax Long Life 75W 90 in Diffs and Transfer box. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
28th Mar 2018 2:40pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello excossack
Castrol 75W-90... March 2017 Price But in the end I went for Motul Gear 300 75W-90 for an all Transmission Oils change (10 Lts required) I did this on the recommendations of Opie Oils, as the Motul looks to be a slightly higher spec' than the Castrol, and qualifies as a Racing Oil. March 2017 Price So for a Puma (Getrag Gearbox MT82) / TD5 (R380 Gearbox) Transmission ... 75W 90 / 3 x 1L Transfer Box (LT230Q / Puma + TD5) + Front & Rear Differentials 75W 90 / 7 x 1L Click image to enlarge Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
28th Mar 2018 3:03pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 930 |
I recently ordered from Opie castrol epx 80/90 for diffs and Castrol syntrans 75/90 for transfer box. Then lr mtf94 for main gearbox from different supplier on eBay.
28th Mar 2018 3:52pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5852 |
Cheers X4SKP, Motul is currently at £14.50 a litre. Pity its just 1L containers. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
28th Mar 2018 5:38pm |
After a bit of hunting ended up with 5litre of Granville oil and 5litre of Croma oil. 1999 Defender TD5 110
29th Mar 2018 6:33pm |
