Home > Maintenance & Modifications > Fitting a new exhaust system on Puma 90
TOP5N
I have just purchased a new DPF back exhaust system from Twisted Automotive, would you say it is an easy DIY job to do, or am i better off taking it to a garage to get done...
Post #696555 27th Mar 2018 7:06pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
I vote for easy.
Be prepared for Some rusted bolts and nuts. But if you replace the current system you can allways use the grinder Thumbs Up a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #696560 27th Mar 2018 7:29pm
bankz5152
Easy DIY, refit with new nuts and bolts though!
Post #696567 27th Mar 2018 7:53pm
jst
easy, if you have a grinder to hand for just in case they dont come undone - and some glasses! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #696573 27th Mar 2018 8:05pm
If you did need a grinder you'd need a larger one too I'd have thought due to disc cutting depth.
A small one would be much more easier to use, but cutting depth wouldn't be right through.
Or carefully use a sabre saw, much less sparks etc Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #696577 27th Mar 2018 8:20pm
TOP5N
All done. I used a jigsaw in the end to cut the back box off, but other than that it was a pretty straight forward job.. Needed to take the rear wheel off the allow the rear bend on the exit pipe through.
Post #697473 31st Mar 2018 4:57pm
CarMan
Pics Question Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #697474 31st Mar 2018 5:00pm
Thumbs Up Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #697475 31st Mar 2018 5:03pm
TOP5N
I’ll pop some pics on tomorrow or monday... i’m aching so much from fitting it all i had to come straight in and have a warm bath Laughing
Post #697480 31st Mar 2018 5:25pm
CarMan
Suggest a glass of something will also help a lot Thumbs Up
Post #697485 31st Mar 2018 5:41pm
