Home > Maintenance & Modifications > Fitting a new exhaust system on Puma 90 |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
I vote for easy.
Be prepared for Some rusted bolts and nuts. But if you replace the current system you can allways use the grinder a defender from 1984 pretending to be a puma with a touch of Range Rover |
27th Mar 2018 7:29pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2166 |
Easy DIY, refit with new nuts and bolts though!
27th Mar 2018 7:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8027 |
easy, if you have a grinder to hand for just in case they dont come undone - and some glasses! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Mar 2018 8:05pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
If you did need a grinder you'd need a larger one too I'd have thought due to disc cutting depth.
A small one would be much more easier to use, but cutting depth wouldn't be right through. Or carefully use a sabre saw, much less sparks etc $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
27th Mar 2018 8:20pm |
TOP5N Member Since: 03 Nov 2015 Location: Gloucester Posts: 226 |
All done. I used a jigsaw in the end to cut the back box off, but other than that it was a pretty straight forward job.. Needed to take the rear wheel off the allow the rear bend on the exit pipe through.
31st Mar 2018 4:57pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1861 |
Pics Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
31st Mar 2018 5:00pm |
31st Mar 2018 5:03pm |
I’ll pop some pics on tomorrow or monday... i’m aching so much from fitting it all i had to come straight in and have a warm bath
31st Mar 2018 5:25pm |
Suggest a glass of something will also help a lot
31st Mar 2018 5:41pm |
