![]() | Home > 130 > Cartoonheads overland 130 thread |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Miss my 130
![]() Very cool truck ![]() |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I would get a better pedal lock as well.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
I highly recommend the Safe-T-Pedal, heavy, cumbersome, not easy to store but a great fit on the Puma and seems very very strong and secure. James
cartoonhead Member Since: 02 Mar 2018 Location: Bucks Posts: 135 ![]() ![]() ![]() |
Alright so done a few things to the 130:
- canvas and sticks off ready for when the hardtop arrives - blindo wheels fitted (turning circle is soooooooo much better now) - dirt d-fenders fitted to hopefully stop too much dirt getting up the sides - genuine LR raised air intake fitted - cargo bear roof rack fitted (rack over the cab and I have 3x cargo bear roof bars to go over the hardtop at the back for the roof tent) - thanks Brendan ![]() Pics: ![]() Click image to enlarge ![]() Click image to enlarge |
Oh I forgot to add - front bumper has been replaced with a HD first four unit with square hitch receiver and the standard tow bar has been replaced with one that has a hitch receiver and a hitch drop plate.
I'm got a portable warn winch coming that will be mountable front or rear on these hitches. |
That looks awesome! Very purposeful, just great. James
What top are you fitting
I’ve got one of these being built with side doors: https://www.tembo4x4-elv.com/Tembo-4x4-Har...fender-130
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 ![]() ![]() ![]() |
Very cool Keith
Same as mine then an AFN from Portugal
![]() Is the company your dealing with used to be called Daams ? Last edited by mick on 26th Mar 2018 9:06am. Edited 1 time in total |
Yep! Just that mine has opening sides - like this:
![]() Click image to enlarge Very nice 130 by the way Mick ![]() |
Cracking bit of kit mine is in everyday use and still like new just a bit of paint bubble round the rivets
I can see me putting my snorkel back on looking at yours ![]() |
When you get the top check its square/straight before you accept it. Measure it diagonally to make sure it is square. Also bear in mind that the tub on the 130 may be out of square (I bet it is) if the tub is out one way and the top out the other way there could be 40mm difference corner to corner. I had a hell of a job fitting mine.
Grease all the latches, you may need to remove them to do this, its better to do it before full assembly as it will be a lot easier. The latches are heavy duty and will get stiff if left dry. ![]() Click image to enlarge 130's have feeling's as well you know ![]() |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
It's back..... my long lost 130 love
![]() Diet Coke break ![]() 1995 110 300TDI 1995 90 300TDI |
