Home > Puma (Tdci) > If your stuck in first gear (how to with pics)
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I know it’s been talked about on here, but no photos exist in the threads,
I’ve just had a 59 reg 90 brought in on a recovery truck, which is well and truly stuck in first gear.
Remove gear stick, and hi low levers,
Remove the 4x bolts holding the alloy gear stick housing and pull to one side.
Remove the black plastic tunnel held in with TX27 screws,
Then you will see the two Detent plugs, one horizontal, one vertical.
Gently tap out the vertical one, being careful not to drop the spring or ball bearing.
Jack up the N/S front wheel, then insert a flat screwdriver and gently move the selector rail towards the front of the box,
You should feel it go, then check on the front wheel to see if you have hit neutral.
Refit detent plug (superseded ones are avalible)
Hope this might help someone one day Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #696194 26th Mar 2018 9:03am
MartinK
Thanks for taking the time to write this up Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #696217 26th Mar 2018 10:35am
ian series 1
It was a bit brief, but didn’t have much time Thumbs Up 80" 80" 86" 88" 90"
Post #696220 26th Mar 2018 10:41am
Very useful, Ian, thanks for posting! Thumbs Up
In the photos it looks to me as though it is the vertical detent that you've removed though.
Post #696229 26th Mar 2018 11:01am
ian series 1
Yep, sorry. Embarassed
Have amended post, like I say, it was all done in a hurry today! Thumbs Up 80" 80" 86" 88" 90"
Post #696242 26th Mar 2018 11:51am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Thanks Ian - filed under "Stuff that may be vital when I'm least expecting it" Bow down
Post #696246 26th Mar 2018 11:59am
ian series 1
It’s a half hour job,
Not sure what it would cost at a dealership?
Apparently there there is an official LR repair kit for this now,
Which requires the box to be split.
At least this would get you out of trouble! Wink 80" 80" 86" 88" 90"
Post #696248 26th Mar 2018 12:07pm
JOW240725
Thanks, Ian! Thumbs Up
I hope I never need it but will be very useful if I do.
Does this affect any particular Defenders? James
Instagram @suffolk_rovers
Post #696251 26th Mar 2018 12:46pm
ian series 1
Not sure James,
I think it’s earlier ones? 80" 80" 86" 88" 90"
Post #696252 26th Mar 2018 12:54pm
JOW240725
Thanks Ian, fingers crossed. Thumbs Up Bow down James
Post #696254 26th Mar 2018 12:56pm
sailawaybrad
Anyone got the product code for the new detent plug? 2011 2.4 110 Utility Wagon
1963 2.25 88 Soft top
Post #755534 1st Feb 2019 7:29pm
Excellent Ian, can prove invaluable if anyone should need it. Thumbs Up
Correct me if I'm wrong but surely the best way of avoiding this happening is not the leave it in gear full stop except for a situation where maybe for safety's sake you have to put it in gear. I.e. Parking on steep hills etc.
I suppose where you have to park at home regularly can have a bearing on it though, my parking place is perfectly flat but not everyone has the same. Chillin In The Backwoods🇬🇧🇺🇸
Post #755539 1st Feb 2019 7:49pm
sailawaybrad
Detent kit is LR017294 for anyone else! 2011 2.4 110 Utility Wagon
Post #757188 7th Feb 2019 8:54pm
Scrawf
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Tamar Blue
Thank god for Defender2.Net and thanks to ian series 1 for his write up!
I had exactly this problem to day. Have the truck up on ramps so I could fit some new side steps more easily. Put it in first for a bit more security (never like relying on the hand brake when I'm underneath!) . Finished the job and tried to mover her off and stuck in first! Really strange as it's never don that before.
Anyway followed ian series 1's instructions and she's got a gearbox again! Thanks fella!
I must say its a pain getting the tunnel and carpets off but well worth it as while I was there I took the opportunity to clean and re-grease everything down there.
Post #760858 26th Feb 2019 5:52pm
Andy T
United Kingdom 2011 Defender 110 Puma 2.4 SW Fuji White
Really useful thread, thank you
Just to say that today the cheapest I can find from 'usual suspects' in UK (LR direct, Britcar, Craddock etc) is £102 plus postage
However FleaBay have the same thing from Poland for £47.76 including postage Very Happy 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM
2015 2.2 Corris Grey 90
2009 2.4 Alaska White 110 Commercial - gone
2006 TD5 Barolo Black 90 - gone
1995 TD5 Green 90 - gone
1984 2.25 Marine Blue 88
Post #833654 27th May 2020 9:24am
