Home > Puma (Tdci) > Broken turbo studs .. how can I get this stud out? :(
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I've noticed that my turbo gasket was blowing (again) and found that 2 of the 3 studs had snapped off leaving the turbo connected to the manifold by just one stud.
Question is, how can I get this stud out of the manifold without the hassle of taking it off?
 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #696039 25th Mar 2018 12:16pm
UtilityTruck
That top one with the clearance hole, you should be able to drill out and re-tap the manifold. The one with the blind hole is going to be pretty tricky. Good luck! 2014 Keswick Utility 2.2
Post #696041 25th Mar 2018 12:19pm
bankz5152
I would remove it and do it on the bench. I tried the same on my TD5 and went through 3 drill bits even using cutting fluid before I got through it.
Post #696046 25th Mar 2018 12:48pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
As bankz says, after much experience of Series exhaust manifold studs (where there is much more clearance) the only way to get a good result is on the bench.
Thumbs Up
Post #696072 25th Mar 2018 4:17pm
zsd-puma
As others have said it's going to need the manifold taking off to get good results. If the top one has a hole right the way through then I expect when you start drilling it it'll screw it's self right through and out the other side.
You might be able to find a second hand manifold from a Transit and just swap them over, would save a load of time.
Post #696152 25th Mar 2018 10:40pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Looking at the angle ,you will never get a drill parallel. Remove the manifold as other have said get a set of "easy out "stud extractors and drill a smaller dia hole than the stud, make sure you drill the full depth of the stud and screw in the easy out which have a left hand thread so as it tightens up it unscrews the stud . Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #696192 26th Mar 2018 9:00am
You might get a compact right-angle drill in there, but it will be extremely difficult to drill the stud co-axially along its length.
Post #696230 26th Mar 2018 11:04am
