Home > My Defender > What Did You Do In Your Defender Today |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 |
Gave the door latches a spray down just now there, one was sticking shut! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
23rd Mar 2018 4:31pm |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
Learning how to solder
Red wire of the electric window was broken an the Blue one was already teared. a defender from 1984 pretending to be a puma with a touch of Range Rover |
23rd Mar 2018 4:37pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 357 |
Fitted a snorkel and some wing top chequer plate.
Click image to enlarge Keith |
24th Mar 2018 8:58am |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Happy to stand corrected but isn't the air intake on a Puma on the side of the wing like it is on Td5/300Tdi? If so, what is your snorkel connected to?
24th Mar 2018 9:48am |
Until this morning it was. The new one runs down through the top of the wing with a new hose straight to the inlet of the airbox.
I just need to decide what to do with the KBX grill in the wing. Keith |
24th Mar 2018 10:02am |
Booked in for an MOT on Monday so decided to sort a few niggles out - adjusted drivers door striker so it closes properly (really needs a new bottom hinge) & then fitted a new indicator switch as the old one cancelled instead of latching & also lights went out completely when going from full to dipped beam
Door now shuts properly but new indicator still won't latch on right turn... left works fine though Guess tomorrow I will be taking it apart again to see if there is anything obvious I have missed - like the arrow pointing right instead of left |
24th Mar 2018 8:43pm |
Took the Wolfs off the 300, put the oe steelies back on.
24th Mar 2018 8:49pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Put my foxwing awning back on for the warmer weather
24th Mar 2018 8:53pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
200 miles round trip to collect this.... So pleased with it
Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
24th Mar 2018 8:59pm |
You'll have to get a foxwing now |
24th Mar 2018 9:04pm |
It's on the list Haven't quite decided which one I like yet though. I'd like a hardshell ostrich wing but not seen one yet, probably cos it's not possible I guess. James
24th Mar 2018 9:09pm |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 |
That's nearly the same size as your barn
24th Mar 2018 9:31pm |
MOT tomorrow and I can't get the bonnet release to pop .
So much for the good intentions of topping up screenwash etc today..... I'll just have to add that to the service list for Engine 710 tomorrow. Turns out its a good job I had it booked in for it's B service together with its MOT . Keith |
25th Mar 2018 7:14am |
Rhi90 Member Since: 05 Nov 2017 Location: Suffolk Posts: 15 |
Great trip out to Thetford today! Sun eventually came out and managed to find some puddles to get dirty in! Massive thanks to my dad for cleaning her already for me!
Click image to enlarge Click image to enlarge Click image to enlarge |
25th Mar 2018 7:19pm |
