Home > In Car Electronics > Defender Security - Immobilise via inertia switch
Page 2 of 2 <12
ssg
Fidely....
Post #695313 21st Mar 2018 9:11pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Thanks. I was referring to "unless it's off which does take a while to restart once reactivated" Smile
Post #695321 21st Mar 2018 9:27pm
ssg
Oh sorry. I switched it off to test and tried to start, nothing as expected but then wouldn't start for a couple of minutes, not turning over as if the battery was flat, then started turning over without starting, then started ok.
Definitely works. If use use as intended there are no problems.
Post #695332 21st Mar 2018 9:44pm
macfrank
Smile
A couple of minutes... Seems a little inconvenient to use in some situations.
Seems the ECU has to perform some post-emergency checks/inits.
Post #695341 21st Mar 2018 9:58pm
ssg
No don't get me wrong, that only happens if you try and start the car with the cut off activated. I did it on purpose to check!
Post #695342 21st Mar 2018 10:00pm
macfrank
aaah, ok! I didn't realise you can (re)start the engine with the inertia switch activated, even if it takes a while, after an accident.
So no delay in everyday use. That's good.
cheers
Frank
Post #695343 21st Mar 2018 10:11pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Hope they get one done for he 2.4 Puma soon My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #695346 21st Mar 2018 10:19pm
Page 2 of 2 <12
