Home > In Car Electronics > Defender Security - Immobilise via inertia switch
Harry.O
I was pondering how to make the 110 a bit harder to steal and the inertia switch under the bonnet came to mind.
If I was to intersect one of the wires e.g. power or earth and run it back to the cab, could a simple on-off switch hidden from view inside prevent the vehicle from being started with the switch in the off position or is it a bit more technical than that?
It's a late TD5 if that makes a difference.
Thanks, Harry 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #690152 2nd Mar 2018 8:10am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
yes, there is a thread on it, let me find it for you My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #690166 2nd Mar 2018 8:54am
meeerrrk
Post #690167 2nd Mar 2018 8:56am
Harry.O
Thanks Meeerrrk, I didn't have much luck with a search, then realised after posting that I'd spelt inertia wrong Embarassed 2005 Td5 110 Hardtop
Post #690178 2nd Mar 2018 9:36am
Screbble
I've sent you a PM Harry Thumbs Up
Post #690331 2nd Mar 2018 7:45pm
Harry.O
Thank you very much Screbble Thumbs Up 2005 Td5 110 Hardtop
Post #691230 5th Mar 2018 6:34pm
Screbble
You're welcome Harry Thumbs Up
Post #691237 5th Mar 2018 6:48pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Post #691399 6th Mar 2018 10:39am
nitram17
They got the idea of someone of here.. think it would cost around10--15 quid to source the components yourself as a one off so I font mind the profit margin...what I do think they could improve it. By increasing the length of the y connector to make it easier to hide.....as if spotted its a case of swapsy and there off... It will stop the dumb theif
Post #691475 6th Mar 2018 4:36pm
myonehere
2007 Defender 90 Puma 2.4 HT Cairns Blue
"...what I do think they could improve it. By increasing the length of the y connector to make it easier to hide.....as if spotted its a case of swapsy and there off... It will stop the dumb thief"
Although, getting the plug off [and back on] the inertia switch was/is a bu**er of a job and, on mine, required unscrewing the switch itself. Only a thief with tiny, strong, triple joined hands could manage to swap back, I feel... but then again, they can be clever bu**ers
Post #691483 6th Mar 2018 5:16pm
nitram17
I dont know if the switch is open or closed when not engaged so someone who knows may comment on what happens if you simply pull out the wires from the inertia switch and join the ends thus making a circuit?Its always best to hide your security devices the best you can..prererably in plain sight!
Post #691631 7th Mar 2018 2:11am
macfrank
Has anyone using this method noticed it may take longer before the engine can be started? Someone over here said so and he was annoyed by it.
Post #694175 17th Mar 2018 9:35pm
ssg
I have just fitted one of these switches, easy job, getting the switch end of the wiring into the passenger compartment was a bit of a pain. The switch doesn't affect starting unless it's off which does take a while to restart once reactivated. I am going to relocate the valve in the engine bay as an extra precaution.
Post #695266 21st Mar 2018 7:08pm
macfrank
Thank you! How long approx. is "a while"? Smile
Post #695304 21st Mar 2018 8:59pm
ssg
Unused some red solid copper coded wire taped to the actual wiring loom and pushed it downward through the bulk head grommet until I could see it through the fuse box appeture, then pulled the cable through. Complete job took about 30 mins in total, just an bit Ridley making the y connection and then finding the red wire to pull through.
Post #695312 21st Mar 2018 9:10pm
