Home > Td5 > Cruise control not working after installing auto box
Page 4 of 4 <1234
geobloke
That is fantastic news MSB WELL DONE Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post #694826 20th Mar 2018 6:57am
mk1collector
Top work msb Thumbs Up thanks for posting this as I'll need to do it when I get mine installed. Ray
My build thread
Post #694956 20th Mar 2018 5:39pm
mk1collector
msb wrote:
Geobloke - basically i got a discovery switch off ebay, a couple of ecu pins and a bit of wire and followed this picture
There was a little more to it, but really not much. For the £20 and the hour so it cost me, it was great mod. As long as you have the standard transfer box (and gearbox) i would recommend it. Let me know if you need any more info or photos Thumbs Up
Grafty - 235/85s so nothing too big. I was wondering about a speedo healer, but wanted to try and understand it all first. I think i need to play around with the Ashcroft ratio tool http://www.ashcroft-transmissions.co.uk/calc/ratio_calc.html
to see what's changed, but does anyone know what exactly in aiming for? What parameters/ range is the ecu looking for?
Thanks
Mike
Just one more question if you can remember, you say you fitted a disco switch, can you remember which colour wires on the switch went to which pin on the ecu? On the switch I have a green a blue and a black and the diagram shows a red a green and an orange
Ray Ray
My build thread
Post #694957 20th Mar 2018 5:45pm
msb
United Kingdom 2004 Defender 90 Td5 PU Coniston Green
The on/off switch is a separate toggle switch, so that's the red on the diagram, feeding 12v into the disco swtich.
The Disco switch has the SET and RES functions, and I've just had a look on ebay and eBay Item No. 183130961613 (which also includes a nice on/off toggle switch) shows three wires; one will be the power in from the on/off toggle switch, and the other two will be when the SET and RES buttons make the respective circuits.
I'm not with the car at the moment, so can't check anything, but a mutlimeter and pressing the switches will tell you which of the three is which.
HTH
Mike
Post #695073 20th Mar 2018 10:24pm
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Hi Gents,
for anybody interested this peice of equipment works fine and one of the best modes for long landy overland drives to Morrocco or Mauri
the cruise control from Nakatamenga
https://thegippo.wordpress.com/2018/01/23/...e-control/
hope it helps Happy Travel
www.thegippo.wordpress.com
Post #729258 16th Sep 2018 2:49pm
Page 4 of 4 <1234
