Home > Td5 > Cruise control not working after installing auto box
Page 2 of 4 <1234>
msb
United Kingdom 2004 Defender 90 Td5 PU Coniston Green
The change in ECU was at the same time, due to it dieing, but not related to the gearbox change.
Since Alive 'made' me a new NNN500020 ECU from my dead one and a NNNsomething else, I did wonder if the problem was in there somewhere, but it does have the same map as the old ECU did when it was a manual.
I know that that needs looking at at some point, but I was hoping to get back to where I was before the ECU and gearbox change before changing anything else.
All being well, I'll make sure the clutch circuit is complete and there is voltage to pin 35 tomorrow, and see if that sovles the problem. Hopefully, it will, if not.... Question
Post #676078 5th Jan 2018 2:42pm
Martin
Site Admin
Clutch switch is a ground signal, and the path is broken when the clutch pedal is pressed.
So you are looking for ground at all times at pin 35 on the black ECU connector.
If you are looking in the engine bay, look for the 2 pin connector with black and black with white stripe wires.
[/quote]  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #676085 5th Jan 2018 2:56pm
msb
Thanks Martin, that makes it easier if I have to resolve at pin 35.
Post #676162 5th Jan 2018 6:54pm
msb
So a new ground at pin 35 brought the orange engine management light on permanently (and I would say it was running a bit rough, but can’t really swear to that)…. so I put the old wire back in.
Nanocom says that the clutch switch is ON, so does that mean it thinks it’s pressed or not?
The manual says that when the clutch is in the rest position, the switch is closed, which allows a feed.. to pin 35.
As far as I can tell, everything else is as it should be:
With Cruise Control master switch (I have a toggle in the circuit) OFF:
Brake switch 1 OFF (ON when pedal pressed)
Brake switch 2 ON (ON when pedal pressed)
Clutch switch ON
Cruise Control OFF
Cruise Resume and Set Accelerate do nothing.
With Cruise Control master switch ON
Brake switch 2 OFF (OFF when pedal pressed)
Clutch switch ON
Cruise Control ON
Cruise Resume ON (MOM) when pressed
Set Accelerate ON (MOM) when pressed
Driving along at 60(ish) the speedo is right, the compushift is right, and Nanocom tells me that the road speed is 95ish, so presumably this is reading in km/h, but the Set Accelerate does not Set…..
Is it still an issue with the clutch switch/pin 35?
Thanks
Post #676372 6th Jan 2018 2:56pm
grafty99
It's hard to tell, have you had no luck finding the plug around the brake master cylinder area? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #676782 7th Jan 2018 10:27pm
msb
Nope, can't find the clutch switch as Ashcroft have "cut, isolated and tucked the wires back in the loom."
Dave says "This is open circuit when you are off the clutch and closed when the clutch is pressed, so its now open all the time"
So similar to Martin's answer.
I don't suppose you have a nanocom and could check yours could you please grafty? Or anyone else?
Thanks
Mike
Post #677001 8th Jan 2018 9:07pm
grafty99
I don't have a nanocom unfortunately, it's something I keep meaning to get! I don't think it is a normally open switch as when I unplug the clutch switch on mine (to improve drivability) the cruise control won't work, which would suggest it's normally closed? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #677005 8th Jan 2018 9:10pm
Martin
Site Admin
Dave's answer is the opposite of mine!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #677006 8th Jan 2018 9:11pm
msb
Sorry, yes (been a long day) Ashcroft says the circuit should be open, you guys ( and actually me from reading the book in an earlier post) say it should be closed.
So, I should look again for the black and black/white wires in the engine bay - does anyone know where they come through the bulkhead or what else they are with? before I go randomly untaping bits of the loom...
Thanks
Post #677010 8th Jan 2018 9:23pm
Martin
Site Admin
Should be near/with the brake fluid level cables I would have thought. Don't have a real Td5 here to refer to though Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #677012 8th Jan 2018 9:24pm
msb
I've just had a very quick look and the brake fluid level cables seem to be on their own and come round on the wing side, there's obviously more cables in the middle but i couldn't really see/ get at them.
There is an unused 4 way plug floating around, but no black or black/white wires....
I should be able to get a look at it in daylight on Thursday...
Post #677028 8th Jan 2018 9:40pm
grafty99
The main loom is in conduit so any excessive tape around the loom should be a bit of a give away Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #677041 8th Jan 2018 9:55pm
miker
I'll have a sit in mine with the nanocom Wednesday AM, and let you know what the clutch switch behaviour is!
Post #677096 9th Jan 2018 12:06am
ashtrans
Site Sponsor
Hi Mike,
I may well be wrong about the switch, especially as grafty99 mentions the cruise doesn't work when the switch is unplugged, I now have a TD5 on the ramp which is going auto this week, I will check the switch and ask our fitter exactly where he hides the wires,
Dave Dave
Post #677552 10th Jan 2018 9:24pm
miker
According to nanocom:
Pedal up - Clutch Switch OFF
Pedal Down - Clutch Switch ON
Post #677611 11th Jan 2018 12:05am
Page 2 of 4 <1234>
