Home > Td5 > wipers... wash & 5x wipe disable?
srod
You know how it is... press the windcreen wash button, you get the required spray of water followed by 5 automatic windscreen wipes. First two clean the windscreen, following three smear it back to worse than what it was when you started.
Is it possible to disable the auto five wipe feature? I.e. washer button just sprays washer fluid. I'll then administer the amount of wipes required manually using the wiper control.
It's fancy dross like this that really lets this Defender down... that and electric windows and central locking... all gimmicks! Very Happy
Post #694595 19th Mar 2018 10:58am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Look at this thread. aka the 99 mod. I've done this myself. I you spray really short the wiper doesn't move.
http://www.defender2.net/forum/topic1810.html?highlight=99 a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #694598 19th Mar 2018 11:03am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
If you replace the standard wiper relay with a '99' variable one then it does just 3 wipes, which is just about right. Plus you get the ability to adjust the intermittent time.
The thread here gives you all the details. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #694599 19th Mar 2018 11:07am
geobloke
That relay is worth its weight in gold. Use the variable intermittent all the time.
Post #694828 20th Mar 2018 7:07am
BLACK LAB
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
ebay link not available now Sad 2006 DEFENDER 90 TD5 CSW XS
2018 RANGE ROVER SPORT HSE DYNAMIC
Post #694834 20th Mar 2018 7:28am
VVS210
^^^^ just type the words VW relay & the part number into the search function & there are loads on eBay Thumbs Up
Post #694866 20th Mar 2018 9:02am
If you have a Defender that doesn't have rear wash/wipe (such as my double cab) an option is to use the redundant RWW wiring instead of the stalk control.
If you fit the rear wash push button switch to the dash, connect the wiring that it already there for the function, fit one fuse in the appropriate empty slot in the CJB fuse box, and connect the rear pump connector tot he pump on the reservoir in place of the screenwash connector, you can have a squirt which is completely independent of the wipers.
it may not be what you want, but I tried this when testing the wiring to use for my headlamp squirters which will run of the otherwise unused rear wash wiring. It is of course no help at all if you have a rear door with wash/wipe!
Post #694872 20th Mar 2018 9:31am
jst
Put it on intermittant first, then press for wash. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #694954 20th Mar 2018 5:26pm
grafty99
Fit the old manual dash pump from a MGB Rolling with laughter 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #695100 20th Mar 2018 11:34pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
another vote for the VW 99 relay here, I found mine on ebay by typing just that into the search
The wash pattern is just about perfect... and as others say the programmable wipe is a godsend in light rain
Post #702996 25th Apr 2018 4:59am
williamthedog
Changed mine a few weeks back Don't know why I waited so long to change it. Paid a tenner for it of the bay of thieves
Post #703066 25th Apr 2018 12:49pm
