![]() | Home > Td5 > wipers... wash & 5x wipe disable? |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Look at this thread. aka the 99 mod. I've done this myself. I you spray really short the wiper doesn't move.
http://www.defender2.net/forum/topic1810.html?highlight=99 a defender from 1984 pretending to be a puma with a touch of Range Rover |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
If you replace the standard wiper relay with a '99' variable one then it does just 3 wipes, which is just about right. Plus you get the ability to adjust the intermittent time.
The thread here gives you all the details. Dave Green Goddess - 1998 Defender 110 300tdi |
That relay is worth its weight in gold. Use the variable intermittent all the time.
BLACK LAB Member Since: 07 Dec 2016 Location: AYRSHIRE Posts: 165 ![]() ![]() ![]() |
ebay link not available now
![]() 2018 RANGE ROVER SPORT HSE DYNAMIC |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
^^^^ just type the words VW relay & the part number into the search function & there are loads on eBay
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
If you have a Defender that doesn't have rear wash/wipe (such as my double cab) an option is to use the redundant RWW wiring instead of the stalk control.
If you fit the rear wash push button switch to the dash, connect the wiring that it already there for the function, fit one fuse in the appropriate empty slot in the CJB fuse box, and connect the rear pump connector tot he pump on the reservoir in place of the screenwash connector, you can have a squirt which is completely independent of the wipers. it may not be what you want, but I tried this when testing the wiring to use for my headlamp squirters which will run of the otherwise unused rear wash wiring. It is of course no help at all if you have a rear door with wash/wipe! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
Put it on intermittant first, then press for wash. Cheers
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Fit the old manual dash pump from a MGB
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
another vote for the VW 99 relay here, I found mine on ebay by typing just that into the search
The wash pattern is just about perfect... and as others say the programmable wipe is a godsend in light rain |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
Changed mine a few weeks back Don't know why I waited so long to change it. Paid a tenner for it of the bay of thieves
