Home > Puma (Tdci) > Radio upgrade... |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Not sure how much "not to expensive" is? But this is the system I just installed in my landy. The head unit is Alpine CDA-117Ri which I got from Car audio direct.I also got the seperate Bluetooth unit KCE-400BT ( as a side note, the OH says the quality of the phone conversation is superb and a lot better than the Plantronics bluetooth headset that I paid £60 for Plus it comes with a Ipod direct control lead allowing the usb connection(which is used to connect the supplied Ipod lead included with the head unit) on the head unit to be used with a memory stick). I am well chuffed with the quality of the sound using the standard speaker setup, although I will be upgrading the speakers and adding an amp unit in the future
I even tuned it into the old foggies radio station RTE on long wave for you too see Click image to enlarge It doesn't look out of place in the dash either, Click image to enlarge I fed the Ipod/usb cable up into the cubby hole to the right of the steering wheel to allow handy access and to keep the installation tidy Click image to enlarge Click image to enlarge Head unit: £253.99 delivered. http://www.caraudiodirect.co.uk/alpine-cda-117ri.html Bluetooth unit: £129.99 delivered. http://www.caraudiodirect.co.uk/alpine-kce-400bt.html Hope this helps and is what you where after Brian. |
2nd May 2011 4:50pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Also uncertain as to "not to expensive" but I have this one
http://www.caraudiodirect.co.uk/alpine-ida-x311.html and my iphone in a brodit mount. upgraded speakers front and rear which were around £100 for the 4. I have a parrot so didnt need the additional bluetooth kit. |
2nd May 2011 5:20pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
thanks chaps, Lorry I can hear 'Morning Ireland' form here 2.4 90 XS
3rd May 2011 7:15am |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
I've just fitted this one
Has ipod control, USB & Bluetooth for phone & audio streaming. |
3rd May 2011 7:24am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
http://www.oxygenaudio.com/lang-en/231-o-line
I was looking at fitting the above stereo anyone else fitted one? Original Member Pie n Pea Club. 110 HCPU Tipper |
3rd May 2011 7:48am |
That's a bit swish Pete, get you
3rd May 2011 8:48am |
All i need is a real iphone istead of the fake one I stole from the shop. Next project connect mini laptop to inset sun visor mounted touch screen for mapping. Original Member Pie n Pea Club.
110 HCPU Tipper |
3rd May 2011 8:57am |
Youre a paradox, Pete. Fly hat and moleskins on the one hand, extreme tech junkie on the other
3rd May 2011 8:58am |
It's a good idea having the Iphone integrated into the head unit, less cables cluttering up the dash. Only downside I can see is when the Iphone 4 is upgraded to Iphone 5, will the new version still work in the head unit? |
3rd May 2011 9:04am |
appen, but we are both happy Original Member Pie n Pea Club. 110 HCPU Tipper |
3rd May 2011 9:11am |
Paradox is that the make of radio I should consider then ? 2.4 90 XS
3rd May 2011 9:23am |
