Home > Technical > no fault codes
BigMike
no fault codes
From reading threads on here about many fault codes being registered, I havent ever had a fault code at all - not even one. Is this unusual? If it is I'll get it looked at but apart from the fuel issue I had whilst I was away (caused by a third party product) I havent had any problems at all with mine and it runs superbly.
Post #68942 28th Apr 2011 4:22pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
What a perfect Defender Shocked Bow down Bow down NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #68948 28th Apr 2011 4:46pm
BigMike
Well this is what I'm thinking about. even the tech at the dealer says its very unusual to have fault codes at all, so either they actually built one correctly or the ecu isnt storing them Laughing
Post #68949 28th Apr 2011 4:56pm
Lorryman100
I would say that you have fault codes stored in the ecu, non tested DTC's that is. IDS only looks for tested DTC's as they are the problem codes. Non tested DTC's are exactly what the name suggests, they go through a number of cycles before clearing or showing up as a tested DTC and illuminating the MIL light. With the nanocom and the remap interface, non tested DTC's appear and disappear over a period of time but do not show up on IDS yet appear on the nanocom/remap interface. The most common I have found are Turbo underboost/overboost, Mass or volume air flow A circuit, Exhaust gas recirculation (EGR) control circuit range/performance and Mass air flow (MAF) sensor in range but higher than expected to name a few. Unless of course you are the only one I know about with a perfect defender that is, if so then please ignore my post Whistle Bow down
Post #68994 28th Apr 2011 11:42pm
BigMike
Cheers Bri. I should probably bite the bullet and get a nanocom but am loathe to give them the business tbh.
Post #69448 3rd May 2011 8:41am
Lorryman100
Mike, pm me your address and I'll special deliver mine down to you to try, and to check your Landy. Just special del it back to me when your finished with it Thumbs Up
Post #69449 3rd May 2011 8:44am
BigMike
Now there's a generous offer if ever there was one. That's very kind of you Bri, will do it now.
Post #69452 3rd May 2011 8:45am
Lorryman100
Remember Mike, you can also get the nanocom from site sponsor Peter at nakatanenga Thumbs Up
Post #69488 3rd May 2011 12:14pm
