Home > Maintenance & Modifications > Wipers
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Wipers
A question for those in the areas that deal with a lot of snow as it's not the usual problem here in the UK but it has become apparent in the snowy weather.
How do you keep your wipers from icing up and becoming useless every 20 minutes or so?
Heated wipers anyone?!
Post #694385 18th Mar 2018 4:07pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Www.heatshot.com Whistle
Also works like a charm on the insects in the summer. Truely can recommend it a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #694417 18th Mar 2018 5:05pm
Jonnyfive
England 2011 Defender 90 Puma 2.4 X-Tech LE Zambezi Silver
Heated screen works for me the other week.
Post #694431 18th Mar 2018 5:33pm
Balvaig
Start by increasing the concentration of your screen wash . Use the concentrated stuff and then you can control it's concentration.
Post #694434 18th Mar 2018 5:56pm
mick
I just use undiluted screen wash all year round
Post #694442 18th Mar 2018 6:14pm
When I asked a similar question in this thread ...
http://www.defender2.net/forum/post690140.html
... Supacat kindly posted the following:
Supacat wrote:
http://www.everblades.com/
Post #694445 18th Mar 2018 6:18pm
Badger110
undiluted screen wash looks to be the simpliest and cheapest answer so far, the heated screen doesn't do anything to help, the build up is far too much for such a weak heat source to do anything.
Those heated wipers do look interesting, but what happens when the blades need replacing...$110 to replace both Shocked
I remember someone on here fitted heated jets ( similar to the heatshot ) from a Rangie, i'll have a look and see if that might work as i want to upgrade the jets and fit a second set...
Cheers all Thumbs Up
Post #694499 18th Mar 2018 9:47pm
