Home > Maintenance & Modifications > Wipers |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
Www.heatshot.com
Also works like a charm on the insects in the summer. Truely can recommend it a defender from 1984 pretending to be a puma with a touch of Range Rover |
18th Mar 2018 4:05pm |
Jonnyfive Member Since: 18 Dec 2016 Location: Devon Posts: 25 |
Heated screen works for me the other week.
18th Mar 2018 4:33pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 730 |
Start by increasing the concentration of your screen wash . Use the concentrated stuff and then you can control it's concentration.
18th Mar 2018 4:56pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
I just use undiluted screen wash all year round
18th Mar 2018 5:14pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17378 |
When I asked a similar question in this thread ...
http://www.defender2.net/forum/post690140.html ... Supacat kindly posted the following:
18th Mar 2018 5:18pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
undiluted screen wash looks to be the simpliest and cheapest answer so far, the heated screen doesn't do anything to help, the build up is far too much for such a weak heat source to do anything.
Those heated wipers do look interesting, but what happens when the blades need replacing...$110 to replace both I remember someone on here fitted heated jets ( similar to the heatshot ) from a Rangie, i'll have a look and see if that might work as i want to upgrade the jets and fit a second set... Cheers all |
18th Mar 2018 8:47pm |
