![]() | Home > Puma (Tdci) > 90 hard top dog guard |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 ![]() ![]() ![]() |
I have a 2015 90 hard top, with the rear bulkhead cut down to half-height, so I can no longer use the bulkhead mounted dog guard.
Does anyone know the difference between these two full height guards, apart from price? https://www.lrparts.net/full-length-dog-gu...-2007.html https://www.lrparts.net/catalogsearch/result/?q=STC50479 First is post 2007, second is TD5. I didn't think there was any significant difference in the rear tub between models? Basically, what would stop me using the cheaper guard? |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
Duckworths have an offer on them at the moment and cheaper than that too
http://www.duckworthparts.co.uk/cgi-bin/sh...21STC50479 |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
In a previous 90 I fitted the Mud bulkhead modification and then fitted a full height cargo barrier behind it.I think I had to do some alterations but nothing major.
Thanks ginjez, sounds like the same set-up as I will end up with.
For those interested, I have fitted the TD5 90 full height dog guard to my 2015 90 with ply lining on the sides, and the bulkhead dropped to half-height. I only had to do slight modifications to the mounting brackets for the lower half of the guard.
