![]() | Home > 130 > Crew cab 2nd row seats storage |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17630 ![]() ![]() ![]() |
It's the most useful storage area on a double cab, you can pack all manner of stuff in there!
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2197 ![]() ![]() |
Been trying to sort something out myself. Currently got a shoddy plastic drawer which I've forced in. Though I think I'll make something better from wood, or maybe ali (thatll cost me though)
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
I assume the bolts, like on our 130, were for the middle seat passenger in a crash. The seats are from a 110 CSW but mounted more upright and therefore probably not designed to lock in that position on a DCPU? 1951 80" S1 2.0
Seats lock fine, just as in an SW. I think the bolts are just to stop rattles and frustrate the owner!
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
I unbolted the seat backs for storage
It's certainly cavernous ![]() Click image to enlarge But what about the space with the seatbox - anyone made use of that? |
On a 110 there is no space in the seatbox, it's full of chassis. On the 130 there is a huge wasted space because the chassis is flat under the seat. See AndrewS's "Longshanks" build thread for pictures.
Ah - that might be what was confusing me - I knew I had seen some photos of a removed seatbox...
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 ![]() ![]() ![]() |
Pre-puma 130s have a removable cover to access the storage area. I put Puma 110 seats in my 130 and found they don’t fit exactly right even with the correct brackets for the rear of the seat. I think Puma 130s must have a slightly different mounting foot for the front of the seat.
One thing I’m contemplating is getting old squar 130 doors and having a drawer from each side of that’s rear seat box. |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 ![]() ![]() ![]() |
I’ve seen I picture where someone had. Put a cabinet hinge on the little triangle bit of body with a sliding bolt to lock it in place. And had then fitted a draw in the seat box.
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 726 ![]() ![]() ![]() |
I’m in the process of affixing the triangular piece to the door so that there’s a square opening, I have a pair of drawers to fit in then where the seat box is. Then either a rear seat from a RR classic or a pair of puma fronts in on the modded seat box..
That’s the plan, anyway.. Cheers alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
remer Member Since: 29 Oct 2016 Location: Perth Posts: 4 ![]() ![]() ![]() |
Heres my setup, really handy for compressor hoses, tyre deflaters, common tools etc
![]() Click image to enlarge Last edited by remer on 10th Mar 2018 10:39pm. Edited 1 time in total |
Here you go:
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
And a couple of other pics I took inspiration from
