Home > 130 > Crew cab 2nd row seats storage
cartoonhead
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Corris Grey
Just wondered if anyone is doing anything interesting with the space available under the rear seats? Thinking about fitting some drawers.
Also, I’ve unbolted the seats from the back of the cab so that I can tilt them forward and store stuff behind them - I assume there is no issue with doing that?
Post #690908 4th Mar 2018 7:06pm
It's the most useful storage area on a double cab, you can pack all manner of stuff in there!
Post #690915 4th Mar 2018 7:29pm
bankz5152
Been trying to sort something out myself. Currently got a shoddy plastic drawer which I've forced in. Though I think I'll make something better from wood, or maybe ali (thatll cost me though)
Post #690918 4th Mar 2018 7:37pm
familymad
I assume the bolts, like on our 130, were for the middle seat passenger in a crash. The seats are from a 110 CSW but mounted more upright and therefore probably not designed to lock in that position on a DCPU? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #690920 4th Mar 2018 7:38pm
Seats lock fine, just as in an SW. I think the bolts are just to stop rattles and frustrate the owner!
Post #690947 4th Mar 2018 8:47pm
mick
I unbolted the seat backs for storage
Post #690949 4th Mar 2018 8:48pm
It's certainly cavernous
But what about the space with the seatbox - anyone made use of that?
Post #691128 5th Mar 2018 12:18pm
On a 110 there is no space in the seatbox, it's full of chassis. On the 130 there is a huge wasted space because the chassis is flat under the seat. See AndrewS's "Longshanks" build thread for pictures.
Post #691135 5th Mar 2018 1:02pm
Ah - that might be what was confusing me - I knew I had seen some photos of a removed seatbox...
Post #691144 5th Mar 2018 1:45pm
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
Pre-puma 130s have a removable cover to access the storage area. I put Puma 110 seats in my 130 and found they don’t fit exactly right even with the correct brackets for the rear of the seat. I think Puma 130s must have a slightly different mounting foot for the front of the seat.
One thing I’m contemplating is getting old squar 130 doors and having a drawer from each side of that’s rear seat box.
Post #691229 5th Mar 2018 7:33pm
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
I’ve seen I picture where someone had. Put a cabinet hinge on the little triangle bit of body with a sliding bolt to lock it in place. And had then fitted a draw in the seat box.
Post #692348 10th Mar 2018 7:49am
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
I’m in the process of affixing the triangular piece to the door so that there’s a square opening, I have a pair of drawers to fit in then where the seat box is. Then either a rear seat from a RR classic or a pair of puma fronts in on the modded seat box..
That’s the plan, anyway..
Cheers alex 98 300 tdi 90 project
94 Range Rover vogue 4.2 lse
79 911 sc
08 130 double cab utility
Post #692409 10th Mar 2018 2:20pm
remer
Australia 2002 Defender 130 Td5 HCPU Fuji White
Heres my setup, really handy for compressor hoses, tyre deflaters, common tools etc
Post #692542 10th Mar 2018 11:35pm
Here you go:
 Darren
Post #692543 10th Mar 2018 11:38pm
remer
And a couple of other pics I took inspiration from Wink
Post #692545 10th Mar 2018 11:44pm
