Home > Puma (Tdci) > Rear Speakers Not Working! |
Barry Member Since: 26 Apr 2011 Location: North East Posts: 137 |
I thought the same , there is a balance option on the stereo , can't remember the exact sequence but it is in the manual , hope it turns out to just be the balance
29th Apr 2011 8:04pm |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
If you have added the rear speakers,the wires do not run through to the radio.They end on the firewall in the engine bay. Puma 110 SW
90 V8 SOFT TOP |
29th Apr 2011 8:55pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
For the standard Land Rover radio, you press the volume button 2 secs for menu 1, 5 secs for Menu 2. l-R balance and F-R balance is on one of those menues.
Balance adjustment 1. Short press the volume control repeatedly until BAL is displayed. 2. Rotate the volume control to adjust sound level to the right (R) or left (L) of the vehicle. Fader adjustment 1. Short press the volume control repeatedly until FAD is displayed. 2. Rotate the volume control to adjust the sound level to the front (F) or rear (R) of the vehicle. Settings menu 2 contains more advanced settings that you will not normally change, as described below. |
29th Apr 2011 10:13pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 |
See - http://www.defender2.net/forum/topic6285.html . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
29th Apr 2011 11:52pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
Thanks for that, still cannot see it in my manual so will have a go this evening
30th Apr 2011 6:41pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2395 |
If std, they are not worth it Puma 110" SW
30th Apr 2011 7:59pm |
