Home > Puma (Tdci) > Rear Speakers Not Working!
Zagato
This is the only thing I have come across that is faulty unless I have missed a speaker balance knob somewhere. Anyone else got the same problem?
Post #69044 29th Apr 2011 6:39pm
Barry
I thought the same , there is a balance option on the stereo , can't remember the exact sequence but it is in the manual , hope it turns out to just be the balance
Post #69045 29th Apr 2011 7:04pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
If you have added the rear speakers,the wires do not run through to the radio.They end on the firewall in the engine bay. Puma 110 SW
90 V8 SOFT TOP
Post #69050 29th Apr 2011 7:55pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
For the standard Land Rover radio, you press the volume button 2 secs for menu 1, 5 secs for Menu 2. l-R balance and F-R balance is on one of those menues.
Balance adjustment 1. Short press the volume control repeatedly
until BAL is displayed.
2. Rotate the volume control to adjust sound level to the right (R) or left (L) of the vehicle.
Fader adjustment 1. Short press the volume control repeatedly
until FAD is displayed.
2. Rotate the volume control to adjust the sound level to the front (F) or rear (R) of the vehicle.
Settings menu 2 contains more advanced settings that you will not normally change, as described below.
Post #69059 29th Apr 2011 9:13pm
PaulMc
See - http://www.defender2.net/forum/topic6285.html
. Paul.
Post #69065 29th Apr 2011 10:52pm
Zagato
Thanks for that, still cannot see it in my manual so will have a go this evening Thumbs Up
Post #69121 30th Apr 2011 5:41pm
MK
If std, they are not worth it Whistle Puma 110" SW
Post #69131 30th Apr 2011 6:59pm
