Home > Maintenance & Modifications > Wet footwell
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Wet footwell
In the previous 2 Defenders i've owned, this issue has never really bothered me as they were work trucks primarily and as long as the rust was kept on top of, i lived with it.
However this new truck is going to primarily be a camper conversion, so it needs to be dry.
So any ideas where the water in the passenger footwell is likely to be coming from?
The N/S bulkhead in the footwell is wet as well as the floor pan itself.
Door seals are all in good condition however i have noticed water on the inside of the seal just below the dash which makes me think it's coming in from behind the dash and tracking down the N/S of the vehicle.
On the old cabs it was mostly windscreen seals, vent seals or door seals. The windscreen and door seals look good and i have no vents at the front, so it's a process of elimination with which i hand over to those working on a similar issue with the later non vented defenders to air their views/opinions
Cheers!
Post #690544 3rd Mar 2018 5:09pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Post #690572 3rd Mar 2018 6:07pm
Badger110
I've just found that!
Dash is coming out tomorrow for wiper and wash jet sorting out jobs, so i'll take it all into consideration Wink
Post #690581 3rd Mar 2018 6:20pm
gilarion
Your avatar looks like my old grandad after partaking of a bottle of Scotish wine, which he did reguarly Laughing
Sadly he passed away many years ago. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #690594 3rd Mar 2018 6:40pm
Badger110
Mr. Green Thumbs Up
Post #690602 3rd Mar 2018 6:56pm
justinp
Check the drain valve on the blower inlet isn’t blocked. Now gone - 2012 2.2 110 DC XS
Post #690634 3rd Mar 2018 8:34pm
Screbble
8619simon wrote:
I found this quite useful:
http://www.landroverweb.com/Pdf-files/Manu...Manual.pdf
This is a really useful manual/bulletin - although it does make me smile - an insight into the weird and wonderful world of Defender ownership - a world that outsiders could not comprehend Rolling with laughter
My footwell leaks originated from the seam between the gutter and roof above the front door- a hair line crack, and the faux windscreen hinges - the gaskets. Both resolved for pennies and although I am tempting fate, I have had dry footweells since Thumbs Up
Post #690815 4th Mar 2018 12:20pm
Balvaig
Mine was the gutter discharging water onto the door seal at the kink. This ran along the door strap and into the footwell.
You just have to work through the options using a hose and flashlight. You can cure the leak -eventually.
Good hunting
Post #690832 4th Mar 2018 1:26pm
