Home > Puma (Tdci) > what is the 2.2 Puma battery type |
Puma no smart alternator. Standard wet cell battery will do, otherwise LR would never have installed it, no?
If you do a search on here you will get a zillion threads on batteries. Like the one below for instance. The most educated battery explanation and advise is given by user tatra805. First thread below, worth reading. Eric http://www.defender2.net/forum/topic16605....arta+lfd90 http://www.defender2.net/forum/topic54344....p;start=15 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
1st Mar 2018 7:18am |
The alternator is just a normal one.
I fitted a Yuasa battery from Halfords. 5 year warranty, same size and a greater capacity and CCA than the factory battery. Genuine batteries are good and last well, but they're not magical as some would have you believe. They are however extremely expensive. About £200 last time I looked, which is twice what I paid for my Yuasa one which will from experience last much longer than the 5 year warranty. While Land Rover batteries do generally last many years, they still only come with the standard 2 year Land Rover parts warranty. |
1st Mar 2018 12:46pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Varta LFD 90
1st Mar 2018 1:00pm |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Hi zsd What was the reference for the Yuasa please? |
1st Mar 2018 5:55pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
Varta every time |
1st Mar 2018 6:30pm |
It's an 019. This one; http://www.halfords.com/motoring/bulbs-bla...ar-battery |
2nd Mar 2018 6:26am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Magneti Marelli ETS100D1N
100Ah 1000A (EN), 650A (ICE) L=353 B=175 H=190 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
2nd Mar 2018 8:31am |
VARTA Professional Dual Purpose AGM LA 95 - 840 095 085
Click image to enlarge https://www.varta-automotive.it/it-it/prod...40-095-085 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
2nd Mar 2018 8:48am |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
Yuasa are usually a good make, used them on bikes and stuff for years, but have not tried the larger ranges as they aren't readily available here.
The best factory ones were about fifteen years ago, when they were Delphi - they lasted forever. I sold my Discovery 2 at 13 years old with the original Delphi factory fitted battery still in it, though it was getting a bit tired by then! The later 'genuine parts' ones I think are now mostly Varta where there is branding, and whatever they fit appears to be much lower quality. I bought a 110Ah Td5 battery for my 300Tdi 110 about three or four years ago but they just don't seem to hold their charge like the old ones did, on a vehicle that is not used much, mine doesn't have an alarm or anything to drain it either. --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
3rd Mar 2018 9:23pm |
